Converting from Comodo
My domain is: https://www.devrod.com
My web server: Apache
My Sever OS:14.04 Ubuntu
My current CA: Comodo. Of course their “free” Certificates are a ploy to sell certificates.
I want to change to a CA that will continue to be free. It took me over 2 days to figure out how to apply the Comodo certificates and I don’t want to change CAs every 90 days.
So, 1. Are your certificates free, always? 2. do I need to remove the Comodo certificates before I use the Certbot? 3. any other guidance?
Yes
  1. do I need to remove the Comodo certificates before I use the Certbot?
No
  1. any other guidance?
I’d suggest starting with https://letsencrypt.org/getting-started/ and set up certbot to automatically renew the certificates for you ( so you can largely forget about it once done, as the update process will be automatic).
Do you have SSH / root access to your server ? or is this on shared hosting ?
Yes, the server is setting just behind me. I will begin your suggestions later this afternoon.
Thank You!
