gfelot
April 10, 2018, 6:35am
1
I have my own website to my own vps. I wanted to work a bit on it but I just saw that now I cannot connect to gilfelot.com .
I try to renew the cert but everything is ok. I didn’t touch my nginx config since so I have no clue where to look at to solve this issue.
I can ssh/ping my server and I even can see it when I try the pingdom tool to score my website.
Thanks.
_az
April 10, 2018, 6:52am
2
Are you trying to connect to it over IPv6 by any chance?
IPv4 is working fine but IPv6 just blows up.
$ curl -i -6 https://gilfelot.com
curl: (35) Encountered end of file
IOW, your IPv6 setup for that domain is not working.
gfelot
April 10, 2018, 4:39pm
3
Yes you right I just check myself. Totaly forget to test this.
I don’t know what’s wrong because I have setup my nginx to accept ipv6.
listen 80;
listen [::]:80;
server_name www.gilfelot.com gilfelot.com;
return 301 https://gilfelot.com$request_uri;
listen 443;
listen [::]:443;
server_name www.gilfelot.com;
root /var/www/html;
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name gilfelot.com;
try_files $uri $uri/ =404;
ssl_certificate /etc/letsencrypt/live/gilfelot.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/gilfelot.com/privkey.pem; # managed by Certbot
if ($scheme != "https") {
} # managed by Certbot
Also UFW is correct.
To Action From
Nginx Full ALLOW Anywhere
OpenSSH ALLOW Anywhere
Nginx Full (v6) ALLOW Anywhere (v6)
OpenSSH (v6) ALLOW Anywhere (v6)
Doesn't this need the ssl directives too? I guess maybe it's taking precedence and causing nginx to serve http rather than https on port 443 over ipv6? (not sure why it would behave differently on ipv4 though)
gfelot
April 11, 2018, 5:21am
5
I may left this typo yeah. I added ssl http2
for the 2 mentioned lines but it doesn’t seems to solve the issue.
It needs, at minimum, a certificate and key. (ssl_certificate
and ssl_certificate_key
.) Or else Nginx will malfunction.
gfelot
April 11, 2018, 6:16pm
7
I feel so dumb now… It was simply that… but since Cerbot add an automatic redirection I don’t even need this part.
system
Closed
May 11, 2018, 6:16pm
8
