Connection timeout
My domain is:githireyout.ddns. net
My web server is (include version):apache
The operating system my web server runs on is (include version):ubuntu 14.04lts on virtual box and host is windows 10
My hosting provider, if applicable, is:no ip is my domain provider
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):yes
I get connection timeout during connect(most likely firewall problem). I have opened both ports 80 and 443
I also get connection timeout.
Are you sure that your ISP is allowing port 80 and 443 to reach your device?
Also please validate your present IP - now seen as 102.166.134.169
Hi @steveyout
I see also a timeout. Is there a firewall?
Yes but i have allowed port 80 and 443 and also turned off firewall on the host
Yes i ran sudo ufw status and it shows port 80 and 443 are open
Maybe your ISP doesn’t allow inbound connections on port 80 from the Internet?
So how do i go about it?
Allows this configuration (main system windows 10, virtual box with ubuntu) external connection?
Oh yeah, maybe VirtualBox and/or Windows 10 aren't allowing the connection to reach the VM guest!
I have switched to bridged network on the virtual box but it doesnt work either
Yes main system is windows 10 and ubuntu is running on virtual box
