Hello, I am trying to set up HTTPS on my Apache2 server,
But the connection times out, but the website is live
What can I do?
Here is the console output:
1: fluffykillers.com
2: boards.fluffykillers.com
3: cloud.fluffykillers.com
4: www.fluffykillers.com
blank to select all options shown (Enter 'c' to cancel):1
tls-sni-01 challenge for fluffykillers.com
Enabled Apache socache_shmcb module
Enabled Apache ssl module
/usr/lib/python2.7/dist-packages/OpenSSL/rand.py:58: UserWarning: implicit cast from 'char *' to a different pointer
type: will be forbidden in the future (check that the types are as you expect; use an explicit ffi.cast() if they are correct)
result_code = _lib.RAND_bytes(result_buffer, num_bytes)
Failed authorization procedure. fluffykillers.com (tls-sni-01): urn:acme:error:connection :: The server could not connect
to the client to verify the domain :: Timeout
Domain: fluffykillers.com
Type: connection
Detail: Timeout
