My domain is: shortgrass.ca
I ran this command: certbot run -v
root@ModX:/var/log/letsencrypt# certbot run -v
1: shortgdev.ca
2: alcoma.shortgdev.ca
3: bassano.shortgdev.ca
4: bowisland.shortgdev.ca
5: brooks.shortgdev.ca
6: duchess.shortgdev.ca
7: foremost.shortgdev.ca
8: gem.shortgdev.ca
9: graham.shortgdev.ca
10: irvine.shortgdev.ca
11: mhpl.shortgdev.ca
12: redcliff.shortgdev.ca
13: rollinghills.shortgdev.ca
14: rosemary.shortgdev.ca
15: tilley.shortgdev.ca
16: www.shortgdev.ca
17: shortgrass.ca
18: alcoma.shortgrass.ca
19: bassano.shortgrass.ca
20: bowisland.shortgrass.ca
21: brooks.shortgrass.ca
22: duchess.shortgrass.ca
23: foremost.shortgrass.ca
24: gem.shortgrass.ca
25: graham.shortgrass.ca
26: irvine.shortgrass.ca
27: mhpl.shortgrass.ca
28: redcliff.shortgrass.ca
29: rollinghills.shortgrass.ca
30: rosemary.shortgrass.ca
31: tilley.shortgrass.ca
32: www.shortgrass.ca
requested (ref: /etc/letsencrypt/renewal/shortgrass.ca.conf)
It contains these names: shortgrass.ca, alcoma.shortgrass.ca,
bassano.shortgrass.ca, bowisland.shortgrass.ca, brooks.shortgrass.ca,
duchess.shortgrass.ca, foremost.shortgrass.ca, gem.shortgrass.ca,
graham.shortgrass.ca, irvine.shortgrass.ca, mhpl.shortgrass.ca,
redcliff.shortgrass.ca, rollinghills.shortgrass.ca, rosemary.shortgrass.ca,
tilley.shortgrass.ca, www.shortgrass.ca
You requested these names for the new certificate: shortgdev.ca,
alcoma.shortgdev.ca, bassano.shortgdev.ca, bowisland.shortgdev.ca,
brooks.shortgdev.ca, duchess.shortgdev.ca, foremost.shortgdev.ca,
gem.shortgdev.ca, graham.shortgdev.ca, irvine.shortgdev.ca, mhpl.shortgdev.ca,
redcliff.shortgdev.ca, rollinghills.shortgdev.ca, rosemary.shortgdev.ca,
tilley.shortgdev.ca, www.shortgdev.ca, shortgrass.ca, alcoma.shortgrass.ca,
tilley.shortgrass.ca, www.shortgrass.ca.
certificate?
(E)xpand/(C)ancel: E
Renewing an existing certificate for shortgdev.ca and 31 more domains
http-01 challenge for alcoma.shortgdev.ca
http-01 challenge for bassano.shortgdev.ca
http-01 challenge for bassano.shortgrass.ca
http-01 challenge for bowisland.shortgdev.ca
http-01 challenge for brooks.shortgdev.ca
http-01 challenge for duchess.shortgdev.ca
http-01 challenge for duchess.shortgrass.ca
http-01 challenge for foremost.shortgdev.ca
http-01 challenge for gem.shortgdev.ca
http-01 challenge for graham.shortgdev.ca
http-01 challenge for irvine.shortgdev.ca
http-01 challenge for mhpl.shortgdev.ca
http-01 challenge for redcliff.shortgdev.ca
http-01 challenge for rollinghills.shortgdev.ca
http-01 challenge for rosemary.shortgdev.ca
http-01 challenge for shortgdev.ca
http-01 challenge for shortgrass.ca
http-01 challenge for tilley.shortgdev.ca
http-01 challenge for www.shortgdev.ca
Challenge failed for domain alcoma.shortgdev.ca
Challenge failed for domain bassano.shortgdev.ca
Challenge failed for domain bowisland.shortgdev.ca
Challenge failed for domain brooks.shortgdev.ca
Challenge failed for domain duchess.shortgdev.ca
Challenge failed for domain foremost.shortgdev.ca
Challenge failed for domain gem.shortgdev.ca
Challenge failed for domain graham.shortgdev.ca
Challenge failed for domain irvine.shortgdev.ca
Challenge failed for domain mhpl.shortgdev.ca
Challenge failed for domain redcliff.shortgdev.ca
Challenge failed for domain rollinghills.shortgdev.ca
Challenge failed for domain rosemary.shortgdev.ca
Challenge failed for domain shortgdev.ca
Challenge failed for domain tilley.shortgdev.ca
Challenge failed for domain www.shortgdev.ca
Challenge failed for domain bassano.shortgrass.ca
Challenge failed for domain duchess.shortgrass.ca
Challenge failed for domain shortgrass.ca
Domain: bassano.shortgrass.ca
Type: connection
Detail: During secondary validation: Fetching http://bassano.shortgrass.ca/.well-known/acme-challenge/o3PeHWUVj85_6avnQix6ABHfCPrmIypcIapS9brDUcI: Connection reset by peer
Domain: duchess.shortgrass.ca
Type: connection
Detail: Fetching http://duchess.shortgrass.ca/.well-known/acme-challenge/hcfgStBEOJHihKh-P2biXkuyULv_46xvwA589l3XZcc: Connection reset by peer
Domain: shortgrass.ca
Type: connection
Detail: During secondary validation: Fetching http://shortgrass.ca/.well-known/acme-challenge/U6ASk-GSINi_kMHnEzjbOzVnZAGQbGJwS0a2UJOZBLg: Connection reset by peer
Domain: alcoma.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for alcoma.shortgdev.ca - check that a DNS record exists for this domain
Domain: bassano.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for bassano.shortgdev.ca - check that a DNS record exists for this domain
Domain: bowisland.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for bowisland.shortgdev.ca - check that a DNS record exists for this domain
Domain: brooks.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for brooks.shortgdev.ca - check that a DNS record exists for this domain
Domain: duchess.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for duchess.shortgdev.ca - check that a DNS record exists for this domain
Domain: foremost.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for foremost.shortgdev.ca - check that a DNS record exists for this domain
Domain: gem.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for gem.shortgdev.ca - check that a DNS record exists for this domain
Domain: graham.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for graham.shortgdev.ca - check that a DNS record exists for this domain
Domain: irvine.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for irvine.shortgdev.ca - check that a DNS record exists for this domain
Domain: mhpl.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for mhpl.shortgdev.ca - check that a DNS record exists for this domain
Domain: redcliff.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for redcliff.shortgdev.ca - check that a DNS record exists for this domain
Domain: rollinghills.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for rollinghills.shortgdev.ca - check that a DNS record exists for this domain
Domain: rosemary.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for rosemary.shortgdev.ca - check that a DNS record exists for this domain
Domain: shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for shortgdev.ca - check that a DNS record exists for this domain
Domain: tilley.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for tilley.shortgdev.ca - check that a DNS record exists for this domain
Domain: www.shortgdev.ca
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.shortgdev.ca - check that a DNS record exists for this domain
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 16.04.7 LTS (GNU/Linux 4.4.0-62-generic x86_64)
or certbot-auto --version
if you're using Certbot): certbot 1.20.0
