I’m trying to obtain Certs for my email Server. I’ve opened the firewall on port 443/80 and also set the port-forwarding to my email-server in the router.
Still any attempt to get certificates fail:
certbot certonly --rsa-key-size 4096 -d mail.gabel.net -d imap.gabel.net -d smtp.gabel.net
Domain: mail.gabel.net
Type: connection
Detail: Fetching
http://mail.gabel.net/.well-known/acme-challenge/BaDnBjedXQ1Epc4PUSSVawEGJDUgs29GOc8v7510hvY:
Connection refusedDomain: imap.gabel.net
Type: connection
Detail: Fetching
http://imap.gabel.net/.well-known/acme-challenge/npQwH2hdSCQndoB9eYG0Peel94WlbHJU022RZxvMMOE:
Connection refusedDomain: smtp.gabel.net
Type: connection
Detail: Fetching
http://smtp.gabel.net/.well-known/acme-challenge/0KIviE9pepOobl-v0CfsMxyW71gKNImdxcTMNQM1iC4:
Connection refusedTo fix these errors, please make sure that your domain name was
root@mail: /etc/letsencrypt/live/mail.gabel.net > nslookup mail.gabel.net
Server: 192.168.0.1
Address: 192.168.0.1#53
Non-authoritative answer:
Address: 89.1.173.61
I’m running NO webserver on this machine nor do I want to.
