Cloaked url forward domains, cert problem
Hello. I want to create SSL cert for all my doamains, containing these cloaked url forwards, but it won’t let me do it. i’m not professional porgrammer, just a typical person with some skills. Could someone explain me these errors? How to alow certbot to recognize these domains as url forwards?
Thats the error:
treshcs.cf
-d treshcs.cf -d www.treshcs.cf -d ftp.treshcs.cf -d poczta.treshcs.cf -d wk.treshcs.cf -d waflowakraina.treshcs.cf -d ts.treshcs.cf -d downloads.treshcs.cf -d pinkmod.treshcs.cf -d boty.treshcs.cf
Apache, newest version
Debian 9
Google Cloud VPS
Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
Hi @tresh
your setup with
can't work.
Checking that domain
there is a frame - https://check-your-website.server-daten.de/?q=wk.treshcs.cf
http://wk.treshcs.cf/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Content:
<html> <head> <title></title> <meta name="viewport" content="width=device-width,initial-scale=1"> </head> <!-- This site "wk.treshcs.cf" is using the free URL redirection service at http://freedns.afraid.org/ --> <!-- The real (cloaked URL) site can be found directly at https://treshcs.cf/wk/index.html/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de --> <!-- Please report any abuse of this free service -->
<frameset frameborder="0" border="0" rows="*,100%" cols="100%" marginwidth="0" marginheight="0"> <frame target="random_name_not_taken1" name="random_name_not_taken1" marginwidth="0" marginheight="0" border="0" noresize scrolling="no"> <frame target="random_name_not_taken2" name="random_name_not_taken2" src="https://treshcs.cf/wk/index.html/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de" border="0" noresize>
<noframes>
<a href="https://treshcs.cf/wk/index.html/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de">NOFRAMES: Click here to visit the actual site</a>
 </noframes> </frameset> </html>
That setup can't work. Your wk.treshcs.cf must have an A-entry with the same ip address as your https://treshcs.cf/ has. Or a CNAME with that domain name.
So the Letsencrypt validator sees only frames, not the validation file.
And you must run Certbot on the treshcs.cf domain / ip address.
So is there any way that my idea could work? I want wk.treshcs.cf to redirect to some directory on my server, I don’t want to show adress in url bar so it’s cloaked, but I’d like to have ssl for that. Is this possible somehow? I saw someehere on this forum threads with mail page and ssl for that, so I guess there’s a hope?
As written: You need an A-record, not a wrong frame. So create one. Your main idea is wrong, your frame redirect is the problem.
I don’t understand, I have already wk record with URL forwarding, I tried to create A record with the same name but I can’t.
So I guess there is no other way for cloaked url forwarding to be with ssl?
You would have to remove the URL forwarding, as well as adding a normal A record.
What’s the benefit of the URL forwarding? What does “cloaking” do?
Wouldn’t a wildcard certificate for the main domain be sufficient to cover all of his third level domains (sub-domains)?
