is there way to force it generate for TLS1.0? I could live with that while I update the client problem to support TLS1.2
The cert can be used with any TLS version. It is just your server ciphers that need changing and you can do that manually.
But, I also want to note your www
subdomain CNAMEs to the root domain. That's fine of course but the cert being used for https://fsairlines.net
will fail client validation as it does not have its own name in the cert.
The TLS version has nothing to do with the certificate. You control that in your server configuration.
Good to know, I reverted the change I did give www its own cert.
I checked the apache config and it looks like everthing except SSLv2 is active.
Its curious that it worked fine for over 3 weeks then the problem started after the certificate was renewed.
But it's NOT.
Please show the config.
From mods-available/ssl.conf
# The protocols to enable.
# Available values: all, SSLv3, TLSv1, TLSv1.1, TLSv1.2
# SSL v2 is no longer supported
SSLProtocol all -SSLv3
In the VirtualHost you might have something like:
If so, what is in that conf file?
cat /etc/letsencrypt/options-ssl-apache.conf
# this file. Contents are based on https://ssl-config.mozilla.org
SSLEngine on
# Intermediate configuration, tweak to your needs
SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLCipherSuite ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
SSLHonorCipherOrder off
SSLSessionTickets off
SSLOptions +StrictRequire
# Add vhost name to log entries:
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-agent}i\"" vhost_combined
LogFormat "%v %h %l %u %t \"%r\" %>s %b" vhost_common
That would definitely stifle Win7.
But I'm still not sure what us in use...
Please show:
sudo apachectl -t -D DUMP_VHOSTS
I replaced those two parameters from what was in the old server and now it works. This will be fine for now, its no less secure than the old server. Thanks for your help.
VirtualHost configuration:
*:443 is a NameVirtualHost
default server localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-beta-le-ssl.conf:2)
port 443 namevhost localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-beta-le-ssl.conf:2)
alias beta.fsairlines.net
port 443 namevhost localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-fsa5-le-ssl.conf:2)
alias fsa5.fsairlines.net
port 443 namevhost localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-net-le-ssl.conf:2)
alias fsairlines.net
alias www.fsairlines.net
port 443 namevhost remote.fsairlines.net (/etc/apache2/sites-enabled/000-fsa-remote-le-ssl.conf:2)
port 443 namevhost fsairlines.net (/etc/apache2/sites-enabled/000-fsa-www-le-ssl.conf:2)
alias www.fsairlines.org
*:80 is a NameVirtualHost
default server localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-beta.conf:1)
port 80 namevhost localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-beta.conf:1)
port 80 namevhost localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-fsa5.conf:1)
port 80 namevhost localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-net.conf:1)
port 80 namevhost remote.fsairlines.net (/etc/apache2/sites-enabled/000-fsa-remote.conf:1)
port 80 namevhost localhost.localdomain (/etc/apache2/sites-enabled/000-fsa-www.conf:1)
alias fsairlines.org
The new values in /etc/letsencrypt/options-ssl-apache.conf
> SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
You have multiple name:port
overlaps:
You have multiple
overlaps:
Thanks for pointing that out, I will fix that. Could it have contributed to this problem?
hmm...
If the vhosts are using different settings [files].
@joefremont, please choose a post as "the solution"
You shouldn't edit that file.
It's better if you make a copy and edit the
include /etc/letsencrypt/options-ssl-apache.conf
line to point to your copy. (remove the "managed by certbot" comment )
I have done that. The new parametes in the copy of options-ssl-apache.conf are:
And at this point all is working as it should, Thanks everyone for your help.
