While exploring how to change authenticator I stumbled upon the Certbot Log Directory. Must be the only log not in the MacOS Console App. I has about 17 log file which are grey but fortunately the latest log can be opened so I copied it. It is very long.
Many lines with:
Server: nginx
I copied the Segments of yesterday’s log that look like they are may be helpful.
Segment A
PermissionError: [Errno 13] Permission denied: '/etc/apache2/.certbot.lock'
2022-07-17 21:57:24,873:DEBUG:certbot._internal.plugins.disco:Other error:(PluginEntryPoint#apache): Unable to create a lock file in /etc/apache2. Are you running Certbot with sufficient privileges to modify your Apache configuration?
Segment B
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/plugins/disco.py", line 160, in prepare
self._initialized.prepare()
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/configurator.py", line 397, in prepare
raise errors.PluginError(
certbot.errors.PluginError: Unable to create a lock file in /etc/apache2. Are you running Certbot with sufficient privileges to modify your Apache configuration?
2022-07-17 21:57:24,874:DEBUG:certbot._internal.plugins.disco:No installation (PluginEntryPoint#nginx): Could not find a usable 'nginx' binary. Ensure nginx exists, the binary is executable, and your PATH is set correctly.
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot_nginx/_internal/configurator.py", line 194, in prepare
raise errors.NoInstallationError(
certbot.errors.NoInstallationError: Could not find a usable 'nginx' binary. Ensure nginx exists, the binary is executable, and your PATH is set correctly.
2022-07-17 21:57:24,874:DEBUG:certbot._internal.plugins.selection:Multiple candidate plugins: * standalone
Description: Spin up a temporary webserver
Interfaces: Authenticator, Plugin
Entry point: standalone = certbot._internal.plugins.standalone:Authenticator
Initialized: <certbot._internal.plugins.standalone.Authenticator object at 0x10f58c220>
Prep: True
Segment C
2022-07-17 21:58:46,632:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/auth_handler.py", line 106, in handle_authorizations
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/auth_handler.py", line 206, in _poll_authorizations
2022-07-17 21:58:46,632:DEBUG:certbot._internal.error_handler:Calling registered functions
2022-07-17 21:58:46,632:INFO:certbot._internal.auth_handler:Cleaning up challenges
2022-07-17 21:58:46,632:DEBUG:certbot._internal.plugins.webroot:Removing /usr/local/var/www/.well-known/acme-challenge/vvxpygO7x57sLWt6lzkZNKJSxO0_EB6sT-uK8szaE5w
2022-07-17 21:58:46,632:DEBUG:certbot._internal.plugins.webroot:Removing /usr/local/var/www/.well-known/acme-challenge/kKFlEx0azvr44kA9H8vTO4M4e1Wf3zOJXooHSR2Kb74
2022-07-17 21:58:46,632:DEBUG:certbot._internal.plugins.webroot:Removing /usr/local/var/www/.well-known/acme-challenge/duMCp0K9Htm88aNZ1HS4dMxdxuX0Bd6-KONs5O4OdbU
2022-07-17 21:58:46,633:DEBUG:certbot._internal.plugins.webroot:Removing /usr/local/var/www/.well-known/acme-challenge/mFl3BFmXMFOWlRqDqejWfr2mKfGg65l5vSKHJe4OhcM
2022-07-17 21:58:46,633:DEBUG:certbot._internal.plugins.webroot:All challenges cleaned up
2022-07-17 21:58:46,633:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/local/bin/certbot", line 33, in
sys.exit(load_entry_point('certbot==1.28.0', 'console_scripts', 'certbot')())
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/main.py", line 19, in main
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/main.py", line 1744, in main
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/main.py", line 1591, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/main.py", line 141, in _get_and_save_cert
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/client.py", line 513, in obtain_and_enroll_certificate
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/client.py", line 441, in obtain_certificate
File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot/_internal/client.py", line 493, in _get_order_and_authorizations
2022-07-17 21:58:46,634:ERROR:certbot._internal.log:Some challenges have failed.
I thought it might work by just editing that file and making that change within it.
If that fails, we may need to use the --webroot approach, seeing as:
How is it going to create the acme-challenge directory and file in name directory without write permission?
Last post was wrong, nginx mentions did not change.
These line look like apache is a problem:
/usr/local/etc/certbot/logs/letsencrypt.log:4: 2022-07-18 13:20:23,455:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
/usr/local/etc/certbot/logs/letsencrypt.log:7: 2022-07-18 13:20:23,581:DEBUG:certbot_apache._internal.configurator:Apache version is 2.4.54
/usr/local/etc/certbot/logs/letsencrypt.log:8: 2022-07-18 13:20:23,877:WARNING:certbot_apache._internal.configurator:ssl_module is statically linked but --apache-bin is missing; not disabling session tickets.
/usr/local/etc/certbot/logs/letsencrypt.log:9: 2022-07-18 13:20:23,879:DEBUG:certbot_apache._internal.configurator:Encountered error:
/usr/local/etc/certbot/logs/letsencrypt.log:11: File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/configurator.py", line 394, in prepare
/usr/local/etc/certbot/logs/letsencrypt.log:25: PermissionError: [Errno 13] Permission denied: '/etc/apache2/.certbot.lock'
/usr/local/etc/certbot/logs/letsencrypt.log:26: 2022-07-18 13:20:23,880:DEBUG:certbot._internal.plugins.disco:Other error:(PluginEntryPoint#apache): Unable to create a lock file in /etc/apache2. Are you running Certbot with sufficient privileges to modify your Apache configuration?
/usr/local/etc/certbot/logs/letsencrypt.log:28: File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/configurator.py", line 394, in prepare
/usr/local/etc/certbot/logs/letsencrypt.log:42: PermissionError: [Errno 13] Permission denied: '/etc/apache2/.certbot.lock'
/usr/local/etc/certbot/logs/letsencrypt.log:49: File "/usr/local/Cellar/certbot/1.28.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/configurator.py", line 397, in prepare
/usr/local/etc/certbot/logs/letsencrypt.log:51: certbot.errors.PluginError: Unable to create a lock file in /etc/apache2. Are you running Certbot with sufficient privileges to modify your Apache configuration?
After brew installed Apache the it is located at:
/usr/local/etc/httpd/
But the log show it is also looking at the old location, /etc/Apache2/
There is a way to tell certbot where all the Apache stuff is located.
But (to me) it seems much simpler to ignore the web server altogether and just use --webroot instead.
Try:
