I'm trying to install snikket server and each time i get Challenge failed for domain esmailelbob.xyz
error when snikket start to run let'scrypt but what is odd is when i run certbot
command outside docker it works just great so i'm not sure what causes it break inside docker...
My domain is: esmailelbob.xyz
I ran this command: docker-compose up
root@debian:~/docker-compose/snikket# docker-compose exec snikket_certs cat /var/log/letsencrypt/letsencrypt.log
2021-12-23 11:24:46,874:DEBUG:certbot.main:certbot version: 0.31.0
2021-12-23 11:24:46,875:DEBUG:certbot.main:Arguments: ['-n', '--webroot', '--webroot-path', '/var/www', '--cert-path', '/etc/ssl/certbot', '--keep', '--agree-tos', '--email', 'esmail@esmailelbob.xyz', '--expand', '--allow-subset-of-names', '--config-dir', '/snikket/letsencrypt', '--domain', 'esmailelbob.xyz', '--domain', 'share.esmailelbob.xyz', '--domain', 'groups.esmailelbob.xyz']
2021-12-23 11:24:46,876:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2021-12-23 11:24:46,885:DEBUG:certbot.log:Root logging level set at 20
2021-12-23 11:24:46,885:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2021-12-23 11:24:46,886:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer None
2021-12-23 11:24:46,887:DEBUG:certbot.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0x7f1668414a20>
Prep: True
2021-12-23 11:24:46,887:DEBUG:certbot.plugins.selection:Selected authenticator <certbot.plugins.webroot.Authenticator object at 0x7f1668414a20> and installer None
2021-12-23 11:24:46,887:INFO:certbot.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2021-12-23 11:24:46,906:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2021-12-23 11:24:46,908:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2021-12-23 11:24:47,639:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 658
2021-12-23 11:24:47,640:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 23 Dec 2021 11:24:47 GMT
Content-Length: 658
X-Frame-Options: DENY
"9oS3c7MMyNc": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
2021-12-23 11:24:47,641:DEBUG:acme.client:Requesting fresh nonce
2021-12-23 11:24:47,641:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2021-12-23 11:24:47,873:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2021-12-23 11:24:47,874:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Replay-Nonce: 01024D8CJCkI7ia2pnf-BDRojQjemNIVn-GNtAZBJRSzABw
2021-12-23 11:24:47,874:DEBUG:acme.client:Storing nonce: 01024D8CJCkI7ia2pnf-BDRojQjemNIVn-GNtAZBJRSzABw
2021-12-23 11:24:47,874:DEBUG:acme.client:JWS payload:
b'{\n "contact": [\n "mailto:esmail@esmailelbob.xyz"\n ],\n "termsOfServiceAgreed": true,\n "resource": "new-reg"\n}'
2021-12-23 11:24:47,882:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-acct:
"protected": "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",
"signature": "Ku9Hy4L93FrRlGTbjBqgZQTHlvJk3mC3RGvw2x9tv1GjKwa9iIUcsiv1rNAD8_tarftnYD5XMedcBuHyk2om9Yxz-YAuq6TclqQKm1pg0s1EVqAP7WYsDV30YN2zS6AiwV-s5cSk6DCLMA8XnkHOV7So22PlMgJBPlGIla__CkJQHLP3SN82mFOtrRrkd9_sqZYmFnZWQzRKgFLksQ6EeA32SyPT97T01XYO3sKj3ZQYNPRA81-YQN2NRyOfa5Bm9BzJ1dr3YfheVGir0yOaVmlvMSw2aS9m3VYfqxF1oNtsYPhEhhQq_c0_XAtaWPYsn1Bm4cMiMAD82Sxzp8-1Zw",
"payload": "ewogICJjb250YWN0IjogWwogICAgIm1haWx0bzplc21haWxAZXNtYWlsZWxib2IueHl6IgogIF0sCiAgInRlcm1zT2ZTZXJ2aWNlQWdyZWVkIjogdHJ1ZSwKICAicmVzb3VyY2UiOiAibmV3LXJlZyIKfQ"
2021-12-23 11:24:48,190:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-acct HTTP/1.1" 201 563
2021-12-23 11:24:48,191:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Date: Thu, 23 Dec 2021 11:24:48 GMT
Content-Length: 563
Boulder-Requester: 333092700
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf>;rel="terms-of-service"
Location: https://acme-v02.api.letsencrypt.org/acme/acct/333092700
Replay-Nonce: 01022RqoflNyfXzVh7FyTUNKzppiFdME-ZDQ02KZkQE9BEc
"key": {
"kty": "RSA",
"n": "wg40fgHingWhLf6Z2AmZSH_jzapy-47UdMZMfcgl2Jk26AcMQMu382nJy-zc2SQzt8mBfvpdA4tQEnXXAINzRk5O3XxmIKPsqY1ovzxe7BSpQSK9qDCfPqP5gJ0qiU44slgxLLvvsl1BTEqwIEkqXq0wQm7EC2KAmwQdxvwITwEe_Uzdju52VI3r5Wrt9ThlYRknaKo4RHBxrM7R1uQml-uRv-nGWmlOIHCPABoez3PW3-4C7nEjdrxzE7aCPsHSTgeIVIdGB9Puri1nHy5Lv0IWyHH0yt90RuRwdurqcwYm5Xjjfyzih0JlPV3l_ztyOUnjtHZqrJGrlDQkwXIM2w",
"e": "AQAB"
"contact": [
"initialIp": "41.45.73.75",
"createdAt": "2021-12-23T11:24:48.047153714Z",
"status": "valid"
2021-12-23 11:24:48,191:DEBUG:acme.client:Storing nonce: 01022RqoflNyfXzVh7FyTUNKzppiFdME-ZDQ02KZkQE9BEc
2021-12-23 11:24:48,194:DEBUG:certbot.reporter:Reporting to user: Your account credentials have been saved in your Certbot configuration directory at /snikket/letsencrypt. You should make a secure backup of this folder now. This configuration directory will also contain certificates and private keys obtained by Certbot so making regular backups of this folder is ideal.
2021-12-23 11:24:48,197:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration(key=JWKRSA(key=<ComparableRSAKey(<cryptography.hazmat.backends.openssl.rsa._RSAPublicKey object at 0x7f16683c2208>)>), contact=('mailto:esmail@esmailelbob.xyz',), agreement=None, status='valid', terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/333092700', new_authzr_uri=None, terms_of_service='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'), 9fe9db839755f5eb7ecf4314ede22ce2, Meta(creation_dt=datetime.datetime(2021, 12, 23, 11, 24, 48, tzinfo=<UTC>), creation_host='bd51503ea3b4'))>
2021-12-23 11:24:48,198:INFO:certbot.main:Obtaining a new certificate
2021-12-23 11:24:48,326:DEBUG:certbot.crypto_util:Generating key (2048 bits): /snikket/letsencrypt/keys/0000_key-certbot.pem
2021-12-23 11:24:48,331:DEBUG:certbot.crypto_util:Creating CSR: /snikket/letsencrypt/csr/0000_csr-certbot.pem
2021-12-23 11:24:48,332:DEBUG:acme.client:JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "esmailelbob.xyz"\n },\n {\n "type": "dns",\n "value": "share.esmailelbob.xyz"\n },\n {\n "type": "dns",\n "value": "groups.esmailelbob.xyz"\n }\n ]\n}'
2021-12-23 11:24:48,336:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDIyUnFvZmxOeWZYelZoN0Z5VFVOS3pwcGlGZE1FLVpEUTAyS1prUUU5QkVjIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIifQ",
"signature": "k_gH-m9vCTnHPtzRQVkvR3uq4ZAkbVOmYOCAk3sr_1KNI5ZEiVt9p0XPB3YGZ_jTEt20qKvMySapyVPeJiAfuxgSrRmy7UkHw2h6IlJeihBgAHlzyxp4jzXuVeMZ9yhMXKzWJuKUtldWFI9mEBElyi8stCm52RQtikwAiUjrdvpQaMRXC5nNzuNg3GOveRBm3moFSZ6_6frif5D_hMl65BUqZQUgHOZ1nTGQ5_gqReTUeBRSZTBt_DV89_oieg4QkKm5VAzvWOUoa3vDSsCGFnYB3wsHiPVgPmsQjXEUx1UjYA6QNlUeTj4gKoUY1Ge0x8Sy8FXKyuK5U-cVbuBf1A",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImVzbWFpbGVsYm9iLnh5eiIKICAgIH0sCiAgICB7CiAgICAgICJ0eXBlIjogImRucyIsCiAgICAgICJ2YWx1ZSI6ICJzaGFyZS5lc21haWxlbGJvYi54eXoiCiAgICB9LAogICAgewogICAgICAidHlwZSI6ICJkbnMiLAogICAgICAidmFsdWUiOiAiZ3JvdXBzLmVzbWFpbGVsYm9iLnh5eiIKICAgIH0KICBdCn0"
2021-12-23 11:24:48,791:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 625
2021-12-23 11:24:48,792:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 625
Location: https://acme-v02.api.letsencrypt.org/acme/order/333092700/49524646720
Replay-Nonce: 0101FGuh9KEfbz3sFVtAhwazLhkIHdmfutTi_EVrkGE6bBU
"status": "pending",
"expires": "2021-12-30T11:24:48Z",
"identifiers": [
"type": "dns",
"type": "dns",
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735720",
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735730",
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735740"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/333092700/49524646720"
2021-12-23 11:24:48,792:DEBUG:acme.client:Storing nonce: 0101FGuh9KEfbz3sFVtAhwazLhkIHdmfutTi_EVrkGE6bBU
2021-12-23 11:24:48,793:DEBUG:acme.client:JWS payload:
b''
2021-12-23 11:24:48,796:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735720:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDFGR3VoOUtFZmJ6M3NGVnRBaHdhekxoa0lIZG1mdXRUaV9FVnJrR0U2YkJVIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My82MTIzMTczNTcyMCJ9",
"signature": "IG_Oi8_IPnbxQDz3-VbN0VUb20NVxm9XcRaE6JkTof5JSg5B3Sm3ruxWBQtUazc0VGQNOb3AQedUF75mrN0aIg3ZX1mXdcVc3DM6_xXqXI0_NkpnjYFgKWoSBQTv4lattDoHJFJam9x4Z7p-7rkY43_x70bMWsMHpFj4CySSFgeWdwvU62uVbC8a1LyyudwDBO6VKeEsefDtV9Hff6z_gx0mkf8SGsrUNqlxetzaVjyT5aACdCPbFpzjLPRGlbmruk3b7NrG8gVh5XNzZYbGAOUeDMRmSSTEVd4lOMLuA89JBobL3Ni2f9L5sAYPka9qk-eduxN-JkeKte6Na0q1lw",
"payload": ""
2021-12-23 11:24:49,049:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/61231735720 HTTP/1.1" 200 796
2021-12-23 11:24:49,049:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 796
Replay-Nonce: 0102gQSkUgVDr2oSgIIApTU7ov0BDzB7qKc5z22veZxAxB4
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735720/ogpqGw",
"token": "PAeFhIrEPptslvzVmkZeHzj_S1UahDUYVFq9Py043IE"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735720/Ybnufg",
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735720/AL-zhA",
2021-12-23 11:24:49,049:DEBUG:acme.client:Storing nonce: 0102gQSkUgVDr2oSgIIApTU7ov0BDzB7qKc5z22veZxAxB4
2021-12-23 11:24:49,050:DEBUG:acme.client:JWS payload:
b''
2021-12-23 11:24:49,053:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735730:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDJnUVNrVWdWRHIyb1NnSUlBcFRVN292MEJEekI3cUtjNXoyMnZlWnhBeEI0IiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My82MTIzMTczNTczMCJ9",
"signature": "QZLNgeVv7oi8R0I-Xd_Hn2Eihw_7oXZLBre9XbhZTVtakgzAqeDzMSv-voMI3Sp-nlWX6BOfdjPjUEer4F3CakfTEoDl7sUcLHtmsQNkQZZvoIO9cy3AU0od2_dRqpcF3FzcBiXKAMvavciazuIBh6WWOhztV5K1S_rnhiMfFTaaENGcmchob9g-NaXPsKM_EMxqq7VNWt_7n108kPhhF-UtHKXPMAfLtTy_fcWOgpREwoOqsZnvbwug6Ic80ffIDUGXxUMuKqQAF3YZfWgf1q23vENhlMKylmS6_7YsGTLPJ5iltuDowCT0bWDT2d96YJ8aBSA6zefau1FlKESEgg",
"payload": ""
2021-12-23 11:24:49,300:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/61231735730 HTTP/1.1" 200 803
2021-12-23 11:24:49,301:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 23 Dec 2021 11:24:49 GMT
Content-Length: 803
Replay-Nonce: 0102OItbcbZpB4ENwEMUrQUhTBTSMQ7lKB-LlBbGZYVnBZY
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735730/WsHbhQ",
"token": "o91n9oezBXoxf28ZmWGU06-Kb4IL7olUzBatCygpuR4"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735730/5JBLXw",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735730/Akoo8g",
2021-12-23 11:24:49,301:DEBUG:acme.client:Storing nonce: 0102OItbcbZpB4ENwEMUrQUhTBTSMQ7lKB-LlBbGZYVnBZY
2021-12-23 11:24:49,302:DEBUG:acme.client:JWS payload:
b''
2021-12-23 11:24:49,306:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735740:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDJPSXRiY2JacEI0RU53RU1VclFVaFRCVFNNUTdsS0ItTGxCYkdaWVZuQlpZIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My82MTIzMTczNTc0MCJ9",
"signature": "YCe7OjpDARTBZ0cFmtsMaEqXXnY3gxPAdj6cDLjqa-jz9dmMIW4cylc_Kdw2HElC4LX17Wmy4pEIahytr2XHI_SZGDuktsce6UFLbnmNtuqVSIy6caE-jtRF93r-CJ657W8NfqWWo0s6RkeDnweTsDaYTQA2IPZvdRJX3c2oD-FyUNRc4pPS1jK48xhI83uLDv-P9R8uPYpxhrW_IoifyL54g6sqY8vYG_Fl8ReAOl2aKaXd8ol3Vkl6fGDC3P1Drm-Wc4M6SvN8CNiGCvKN3vPYqFzgt_whGMgQCLYKxE6ex87_nhfvf9WzlqMFsurh_qur-x_sBRTvUMxF7B1t7A",
"payload": ""
2021-12-23 11:24:49,589:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/61231735740 HTTP/1.1" 200 802
2021-12-23 11:24:49,590:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 802
Replay-Nonce: 0102_qRICkGs96_Z92W3jhZDhTa44Yil9Cj2_Y0HXNzwN9I
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735740/DZA3FQ",
"token": "QOH1fDeT1z2cHMXF56Gn9t7AOzP5s6s2kmRcTS0eseY"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735740/pfcguA",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735740/K4SXxA",
2021-12-23 11:24:49,590:DEBUG:acme.client:Storing nonce: 0102_qRICkGs96_Z92W3jhZDhTa44Yil9Cj2_Y0HXNzwN9I
2021-12-23 11:24:49,591:INFO:certbot.auth_handler:Performing the following challenges:
2021-12-23 11:24:49,591:INFO:certbot.auth_handler:http-01 challenge for esmailelbob.xyz
2021-12-23 11:24:49,591:INFO:certbot.auth_handler:http-01 challenge for groups.esmailelbob.xyz
2021-12-23 11:24:49,591:INFO:certbot.auth_handler:http-01 challenge for share.esmailelbob.xyz
2021-12-23 11:24:49,592:INFO:certbot.plugins.webroot:Using the webroot path /var/www for all unmatched domains.
2021-12-23 11:24:49,592:DEBUG:certbot.plugins.webroot:Creating root challenges validation dir at /var/www/.well-known/acme-challenge
2021-12-23 11:24:49,597:DEBUG:certbot.plugins.webroot:Attempting to save validation to /var/www/.well-known/acme-challenge/PAeFhIrEPptslvzVmkZeHzj_S1UahDUYVFq9Py043IE
2021-12-23 11:24:49,601:DEBUG:certbot.plugins.webroot:Attempting to save validation to /var/www/.well-known/acme-challenge/o91n9oezBXoxf28ZmWGU06-Kb4IL7olUzBatCygpuR4
2021-12-23 11:24:49,606:DEBUG:certbot.plugins.webroot:Attempting to save validation to /var/www/.well-known/acme-challenge/QOH1fDeT1z2cHMXF56Gn9t7AOzP5s6s2kmRcTS0eseY
2021-12-23 11:24:49,606:INFO:certbot.auth_handler:Waiting for verification...
2021-12-23 11:24:49,606:DEBUG:acme.client:JWS payload:
b'{\n "resource": "challenge",\n "type": "http-01"\n}'
2021-12-23 11:24:49,610:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735720/ogpqGw:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDJfcVJJQ2tHczk2X1o5MlczamhaRGhUYTQ0WWlsOUNqMl9ZMEhYTnp3TjlJIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My82MTIzMTczNTcyMC9vZ3BxR3cifQ",
"signature": "ObM5xKXrTuLrAyufaRVi2p5g5uLCotOAwik4v_IAZ4VfVMUHMpVleTwJoNw4UiPAF6S2GQePQi1SC8aJdmI1Jjg-sb_IKzsfA5Szv_-cqBOPtjSeCdBvQEsiwGt6aCRueZqB64_-nkcRqci9Zueb03lGhAbs6dpib5-4hntdwGKbgqJMssLx3ZV2SzoWAB9-fKoey5LW9IfeuWQJzodDDhwK4sD9C5wAF1v0RMqSUzi7PKELjTT4rJY86XvIq2ZaU2KNSxQpLH_4LApLoIGjVHT1YSYb3buv9u75W9e8FOR_4Lr_NdjiD4FwXStISX8aeIY-pRkcNThvk2jIUruXJw",
"payload": "ewogICJyZXNvdXJjZSI6ICJjaGFsbGVuZ2UiLAogICJ0eXBlIjogImh0dHAtMDEiCn0"
2021-12-23 11:24:49,874:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/61231735720/ogpqGw HTTP/1.1" 200 186
2021-12-23 11:24:49,875:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 186
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735720>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735720/ogpqGw
Replay-Nonce: 01029lL3UwbyresHdDVITqP59aHZaLI2p0L74D4MZuYqQv8
"type": "http-01",
2021-12-23 11:24:49,875:DEBUG:acme.client:Storing nonce: 01029lL3UwbyresHdDVITqP59aHZaLI2p0L74D4MZuYqQv8
2021-12-23 11:24:49,876:DEBUG:acme.client:JWS payload:
2021-12-23 11:24:49,880:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735730/WsHbhQ:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDI5bEwzVXdieXJlc0hkRFZJVHFQNTlhSFphTEkycDBMNzRENE1adVlxUXY4IiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My82MTIzMTczNTczMC9Xc0hiaFEifQ",
"signature": "H5Jb1ODu5fYftg7a3AhGejm9YdBp5ftAlfwRpfBi7znLAD4BC1lC1vDNipbim56XKiBTNm8NJTQ2jyIHG_fZER5hoRjDEXct3umgBGn5bjR6mDcsITbp4qySSDCIPNmEu6KHW09QpuRhSvqCo_zD0C-DGEl3NPpi9bIn71_3sOo5XFoqXS_UxZtXWqhlA1D9I8HrxnrI0ZsWslSQlk2dyR7ViiXphmmv-zXvdjFl1iT50VCl_uk6pwtgwoE-8WsRFG6otHnNdaHsKvG0YX45LlBc3uYzgHSJOOWVVF7Ah0a5rW-eSgeri-MsgvhxYtH9lCLjrj4hznWcjSfZP21xCA",
2021-12-23 11:24:50,143:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/61231735730/WsHbhQ HTTP/1.1" 200 186
2021-12-23 11:24:50,143:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 23 Dec 2021 11:24:50 GMT
Content-Length: 186
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735730>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735730/WsHbhQ
Replay-Nonce: 0102MX_Al5PRUdyuulILm3HHejPx79W1WIjNOpoyKzbC4Uc
"type": "http-01",
2021-12-23 11:24:50,143:DEBUG:acme.client:Storing nonce: 0102MX_Al5PRUdyuulILm3HHejPx79W1WIjNOpoyKzbC4Uc
2021-12-23 11:24:50,144:DEBUG:acme.client:JWS payload:
2021-12-23 11:24:50,148:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735740/DZA3FQ:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDJNWF9BbDVQUlVkeXV1bElMbTNISGVqUHg3OVcxV0lqTk9wb3lLemJDNFVjIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My82MTIzMTczNTc0MC9EWkEzRlEifQ",
"signature": "j2MI2TkllaRAI2lrRzJy92f23q9a4ndpxuRbFadaw9GuIjR6ZU1oSnGtHy9VKk_PJdch4N9egR2xxiuKvZ0jVZBA1f5-RizyuI4I70bic7ep7o5HHj4VYdYlvEDNjTN_seGO924b1wq2yE8BZoRhD251XHVlfz8_hCqxmp273u83P97jArmBF1-SobXwvYrDfJhN3pAMOXQrxDZWmT8raSAbR4slT0SD8v3XdM2BcYenQ30w2BVcKNS060D_zkNyG7Mp0W9DpEv-XNS6pGdV0EmNteIentGAlXp2_lnvXhIj8a_LPgz9Wwc1JPlrJLFsMgmythGJyAW5JkdyqhUTGA",
2021-12-23 11:24:50,412:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/61231735740/DZA3FQ HTTP/1.1" 200 186
2021-12-23 11:24:50,413:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 186
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735740>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/61231735740/DZA3FQ
Replay-Nonce: 0102bENB-1haWJs5eJ4_4i4tTKxttSE4H4UlfwMRK7sDcPw
"type": "http-01",
2021-12-23 11:24:50,413:DEBUG:acme.client:Storing nonce: 0102bENB-1haWJs5eJ4_4i4tTKxttSE4H4UlfwMRK7sDcPw
2021-12-23 11:24:53,416:DEBUG:acme.client:JWS payload:
b''
2021-12-23 11:24:53,420:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735720:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDJiRU5CLTFoYVdKczVlSjRfNGk0dFRLeHR0U0U0SDRVbGZ3TVJLN3NEY1B3IiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My82MTIzMTczNTcyMCJ9",
"signature": "XS_tMV-LCU1aM8tSk6y4OIKCkWuNsocLvyhE5zIefOHINUJM_xZsT8AvnQDRDLkHbKntmB8HArj9UxjN2soGYZu0P2EPBN10hFj8-ZOGUekChvW8e37e2SS8FXgPaOqzLFS6zbI-hAPcAbBXwKqtE2MFGuwAPEzC8NmGzhxFB_gFkmE2AlS26E3hjqSNxYCm1YSp721LfSo0ZpshwVmX1PbCn93P_Ev3LPwJucqg2fsuQTDO7CJdftzabarlfzTy5DE8QHDMqcTlY2O-RVzLkJI8aEre-DMG61qz7bMPkDxJL5HlhIOnWA5rLQY_EeZGApWpa4w_VdXEH2rrqyowZA",
"payload": ""
2021-12-23 11:24:53,671:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/61231735720 HTTP/1.1" 200 1245
2021-12-23 11:24:53,672:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 23 Dec 2021 11:24:53 GMT
Content-Length: 1245
Replay-Nonce: 0101Q8UcQPElRR0zcrhAPrepbfyTrB4rQhb6h3IjnQH_o2s
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from http://esmailelbob.xyz/.well-known/acme-challenge/PAeFhIrEPptslvzVmkZeHzj_S1UahDUYVFq9Py043IE [41.45.73.75]: \"\u003c!DOCTYPE html\u003e\\n\u003chtml lang=\\\"en\\\"\u003e\\n\\t\u003chead\u003e\\n\\t\\t\\n\\t\\t\u003ctitle\u003eError: Nothing here\u003c/title\u003e\\n\\t\\t\u003cmeta http-equiv=\\\"Content-Type\\\" content=\\\"text\"",
"status": 403
"token": "PAeFhIrEPptslvzVmkZeHzj_S1UahDUYVFq9Py043IE",
"validationRecord": [
"url": "http://esmailelbob.xyz/.well-known/acme-challenge/PAeFhIrEPptslvzVmkZeHzj_S1UahDUYVFq9Py043IE",
"hostname": "esmailelbob.xyz",
"port": "80",
"addressesResolved": [
"41.45.73.75"
"addressUsed": "41.45.73.75"
"validated": "2021-12-23T11:24:49Z"
2021-12-23 11:24:53,672:DEBUG:acme.client:Storing nonce: 0101Q8UcQPElRR0zcrhAPrepbfyTrB4rQhb6h3IjnQH_o2s
2021-12-23 11:24:53,672:WARNING:certbot.auth_handler:Challenge failed for domain esmailelbob.xyz
2021-12-23 11:24:53,673:DEBUG:acme.client:JWS payload:
b''
2021-12-23 11:24:53,677:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735730:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDFROFVjUVBFbFJSMHpjcmhBUHJlcGJmeVRyQjRyUWhiNmgzSWpuUUhfbzJzIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My82MTIzMTczNTczMCJ9",
"signature": "MYE9SjLWAv8Wot4_ZqLJQf6pDWalWiwh-bYsCqAIhUUYajjHH1Wq6Y80u9S_jlssUDXaFyXmn-2W7Qcwk-QYQll6H7j-Tiy-Vp1OHOqFr_GWF1hWyqMC-YsfrR8FIAgKw6M9yvRJyoFDYDV8vJK6E50jOi0EM2rEh26j2EqChk3aTv_YtIopy-zfwhaQmI3v2Zzvl0fDgg9_LkgjYiIkonrmHsQ0cROlT-E8IMpLj_XUQrznKCZ1vZXaneVC3C7zfuOgcmhB6fQP_ijK7DuY94favjFVyyNxxv2bVS-lp-o7P0QJ5a2uKTyFmmB5j5GwJODzO2RnZ76xMYR2t3dllQ",
"payload": ""
2021-12-23 11:24:53,945:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/61231735730 HTTP/1.1" 200 1273
2021-12-23 11:24:53,946:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 1273
Replay-Nonce: 0101gTDVNGVFpUWlSrY06C65_S-84vHLdqXIvh4ffZvDzZc
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"error": {
"detail": "Invalid response from http://groups.esmailelbob.xyz/.well-known/acme-challenge/o91n9oezBXoxf28ZmWGU06-Kb4IL7olUzBatCygpuR4 [41.45.73.75]: \"\u003c!DOCTYPE html\u003e\\n\u003chtml lang=\\\"en\\\"\u003e\\n\\t\u003chead\u003e\\n\\t\\t\\n\\t\\t\u003ctitle\u003eError: Nothing here\u003c/title\u003e\\n\\t\\t\u003cmeta http-equiv=\\\"Content-Type\\\" content=\\\"text\"",
"status": 403
"token": "o91n9oezBXoxf28ZmWGU06-Kb4IL7olUzBatCygpuR4",
"url": "http://groups.esmailelbob.xyz/.well-known/acme-challenge/o91n9oezBXoxf28ZmWGU06-Kb4IL7olUzBatCygpuR4",
"hostname": "groups.esmailelbob.xyz",
"port": "80",
"41.45.73.75"
2021-12-23 11:24:53,946:DEBUG:acme.client:Storing nonce: 0101gTDVNGVFpUWlSrY06C65_S-84vHLdqXIvh4ffZvDzZc
2021-12-23 11:24:53,946:WARNING:certbot.auth_handler:Challenge failed for domain groups.esmailelbob.xyz
2021-12-23 11:24:53,947:DEBUG:acme.client:JWS payload:
b''
2021-12-23 11:24:53,949:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/61231735740:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzMzMDkyNzAwIiwgIm5vbmNlIjogIjAxMDFnVERWTkdWRnBVV2xTclkwNkM2NV9TLTg0dkhMZHFYSXZoNGZmWnZEelpjIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My82MTIzMTczNTc0MCJ9",
"signature": "ayhqxjEDV78ggCKzqV_4b6o-yFbHFySHwEKGfGktv4Fd0X5oPKZuCpFJcDaih5ODmv6GmblKK0mmTBj87CgCRZnD8gJoaQhNhEZUiclDvnecTa1nJ2EkqFqi5KIPxCKUmXys5CA8yHPhJ2vMzlWQpTPZis3hr3AjpgyN3_3XZm6Z08LoDEKurCENib1h8vlFx8FIUNT0sL2T11I3XnEWbFQvuwNH690Z0rPQI2z3BAcvud2Bcw143i5PmbxpYxqyJe8HX40RDE7ZxIq_3-ww1CESLUncIWyXHLmC1LkYmGRiHtZNqczpjG6J0xNX8X561ctec5H78k2u5QrAjB2t5w",
"payload": ""
2021-12-23 11:24:54,217:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/61231735740 HTTP/1.1" 200 1269
2021-12-23 11:24:54,218:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 23 Dec 2021 11:24:54 GMT
Content-Length: 1269
Replay-Nonce: 0102wXDD4tzXS5PpK2T05nZydVoU4n86iXcXT3AZPBASw58
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"error": {
"detail": "Invalid response from http://share.esmailelbob.xyz/.well-known/acme-challenge/QOH1fDeT1z2cHMXF56Gn9t7AOzP5s6s2kmRcTS0eseY [41.45.73.75]: \"\u003c!DOCTYPE html\u003e\\n\u003chtml lang=\\\"en\\\"\u003e\\n\\t\u003chead\u003e\\n\\t\\t\\n\\t\\t\u003ctitle\u003eError: Nothing here\u003c/title\u003e\\n\\t\\t\u003cmeta http-equiv=\\\"Content-Type\\\" content=\\\"text\"",
"status": 403
"token": "QOH1fDeT1z2cHMXF56Gn9t7AOzP5s6s2kmRcTS0eseY",
"url": "http://share.esmailelbob.xyz/.well-known/acme-challenge/QOH1fDeT1z2cHMXF56Gn9t7AOzP5s6s2kmRcTS0eseY",
"hostname": "share.esmailelbob.xyz",
"port": "80",
"41.45.73.75"
"validated": "2021-12-23T11:24:50Z"
2021-12-23 11:24:54,218:DEBUG:acme.client:Storing nonce: 0102wXDD4tzXS5PpK2T05nZydVoU4n86iXcXT3AZPBASw58
2021-12-23 11:24:54,219:WARNING:certbot.auth_handler:Challenge failed for domain share.esmailelbob.xyz
2021-12-23 11:24:54,219:DEBUG:certbot.error_handler:Calling registered functions
2021-12-23 11:24:54,219:INFO:certbot.auth_handler:Cleaning up challenges
2021-12-23 11:24:54,219:DEBUG:certbot.plugins.webroot:Removing /var/www/.well-known/acme-challenge/PAeFhIrEPptslvzVmkZeHzj_S1UahDUYVFq9Py043IE
2021-12-23 11:24:54,219:DEBUG:certbot.plugins.webroot:Removing /var/www/.well-known/acme-challenge/o91n9oezBXoxf28ZmWGU06-Kb4IL7olUzBatCygpuR4
2021-12-23 11:24:54,219:DEBUG:certbot.plugins.webroot:Removing /var/www/.well-known/acme-challenge/QOH1fDeT1z2cHMXF56Gn9t7AOzP5s6s2kmRcTS0eseY
2021-12-23 11:24:54,220:DEBUG:certbot.plugins.webroot:All challenges cleaned up
2021-12-23 11:24:54,220:DEBUG:certbot.log:Exiting abnormally:
File "/usr/bin/certbot", line 11, in <module>
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1250, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 121, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/client.py", line 410, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 353, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 389, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 93, in handle_authorizations
"Challenges failed for all domains")
certbot.errors.AuthorizationError: Challenges failed for all domains
The operating system my web server runs on is (include version): debian 11
My hosting provider, if applicable, is: none, it's self hosted
or certbot-auto --version
if you're using Certbot): certbot 1.12.0
