Hi guys,
I decided to migrate my friend's WordPress website from the docker containers to the LEMP stack and couldn't obtain a certificate due to errors with DNS A/AAAA record(s) however these records have been already configured on a domain site long ago. Uncommenting of the
listen [::]:443 ssl http2 ipv6only=on;
listen 443 ssl http2; # managed by Certbot
doesn't help as well
Could you pls help by any chance?
Nginx config:
root /var/www/catch-22;
index index.php index.html index.htm index.nginx-debian.html;
server_name catch-22.co.nz www.catch-22.co.nz;
# listen [::]:443 ssl http2 ipv6only=on;
# listen 443 ssl http2; # managed by Certbot
client_max_body_size 500M;
#try_files $uri $uri/ =404;
try_files $uri $uri/ /index.php$is_args$args;
location ~ \.php$ {
include fastcgi_params;
fastcgi_intercept_errors on;
# include snippets/fastcgi-php.conf;
fastcgi_pass unix:/var/run/php/php8.1-fpm.sock;
fastcgi_connect_timeout 300s;
fastcgi_read_timeout 300s;
fastcgi_send_timeout 300s;
location ~ /\.ht {
deny all;
location = /favicon.ico { log_not_found off; access_log off; }
location = /robots.txt { log_not_found off; access_log off; allow all; }
location ~* \.(css|gif|ico|jpeg|jpg|js|png)$ {
expires max;
log_not_found off;
location ~ ^/\.user\.ini {
deny all;
# ssl_certificate /etc/letsencrypt/live/catch-22.co.nz/fullchain.pem; # managed by Certbot
# ssl_certificate_key /etc/letsencrypt/live/catch-22.co.nz/privkey.pem; # managed by Certbot
# include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
# ssl_ciphers EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
# ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
The domain is: catch-22.co.nz
I ran this command: sudo certbot --nginx -d catch-22.co.nz -d www.catch-22.co.nz
http-01 challenge for catch-22.co.nz
http-01 challenge for www.catch-22.co.nz
Challenge failed for domain catch-22.co.nz
Challenge failed for domain www.catch-22.co.nz
Domain: catch-22.co.nz
Type: connection
Detail: 130.162.231.184: Fetching
http://catch-22.co.nz/.well-known/acme-challenge/IYaAFXYgylxTaNyb1jeUzJ5CFw4rcRxL97D-XTN5Kog:
Error getting validation data
Domain: www.catch-22.co.nz
Type: connection
http://www.catch-22.co.nz/.well-known/acme-challenge/7U0k2jVws7YQtaO2ffoO36csqJYAbl8yKmrjoXF3FZ4:
My web server is (include version): nginx/1.21.6
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: https://myhost.nz
or certbot-auto --version
if you're using Certbot): certbot 1.12.0
