I fixed the nginx error and now the nginx test passes.
I ran:
certbot -d beehaw.org -d www.beehaw.org
and it worked! Thanks!
I can see both beehaw.org
as wel as www.beehaw.org
are using the single cert with both hostnames in it indeed!
You probably have one of your single-hostname certificate still laying around in Certbot. And the other single-hostname cert is probably expanded into the double-hostname cert currently in use. You can check which certificates are active within Certbot with:
certbot certificates
You should be able to identify the certificate or certificates with just the single hostname fairly easily. Your site now uses the double-hostname-certificate, so you should be able to remove the certificate or certificates with just the single hostname.
Thank you again! I'll be working on that shortly.
I ran:
And got this:
Renewal configuration file /etc/letsencrypt/renewal/beehaw.org.conf produced an unexpected error: expected /etc/letsencrypt/live/beehaw.org/cert.pem to be a symlink. Skipping.
Found the following certs:
Certificate Name: www.beehaw.org
Serial Number: 3473f076c39ab3189b3affb9068462a7263
Key Type: RSA
Domains: beehaw.org www.beehaw.org
Expiry Date: 2022-04-29 21:51:47+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.beehaw.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.beehaw.org/privkey.pem
The following renewal configurations were invalid:
That's interesting.. Why would that configuration file suddenly be invalid..
Well, at least it won't be renewing any unnecessary certificate It's not pretty, but you could just leave it this way..
I'll come back to all this at a later time. However, I appreciate your help. So, thank you.
