Certmgr.mcs dosen't see SSL certificate
My domain is: growattpolska.pl
I ran this command: http://mpsolar.pl/ftp/SSLCert.png
It produced this output: I couldn’t find SSL cert in Certmgr.msc, why …?
My web server is (include version): XData server
The operating system my web server runs on is (include version): Win 7 PRO
My hosting provider, if applicable, is: home.pl
I can login to a root shell on my machine (yes or no, or I don’t know): don’t know
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Certmgr /Windows/
I’m pretty sure it has something to do with the warning on line 4 and 5.
Also, you answered “C:” as the path to the “ISS Central Certificate Store”, which would generate a PFX file. And that fails, as you can clearly see by the error messages near the bottom.
By the way, I think it’s a bug in the client to generate a renewal for a certificate which can’t be stored anyway.
Where does XData server get the certificate from? From Certmgr? Or from a PFX file?
