Try importing the self-signed "ISRG Root X1" (and maybe rebooting afterwards) https://letsencrypt.org/certs/isrgrootx1.der
[download it then double-click it to install it into the Windows Certificate store]
I'm accessing their API from a docker image on ECS in aws. So I would need to create a set of commands in the Dockerfile to run in the build. Does anyone have a straight up fix for this?
So I am having a similar problem with an Alexa skill calling a local Webservice (to control my Sonos system) running on a Pi. The Web call works fine from Chrome browser but when Alexa makes the same call it fails and reports:
Error: certificate has expired
at Error (native)
at TLSSocket. (_tls_wrap.js:1092:38)
at emitNone (events.js:86:13)
at TLSSocket.emit (events.js:185:7)
at TLSSocket._finishInit (_tls_wrap.js:610:8)
at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:440:38) code: 'CERT_HAS_EXPIRED' }
2021-10-02T17:34:36.545Z aaf5a8ee-5b69-49e4-997b-7c8abb13addd { Error: certificate has expired at Error (native) at TLSSocket. (_tls_wrap.js:1092:38) at emitNone (events.js:86:13) at TLSSocket.emit (events.js:185:7) at TLSSocket._finishInit (_tls_wrap.js:610:8) at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:440:38) code: 'CERT_HAS_EXPIRED' }
I have tried renewing my letsencrypt cert but is reports it does not need renewing and as above, the web service is configured to used fullchain.pem. This has worked fine for a number of years and has just recently stopped working. Does anyone have any ideas please? Thanks
