I have been trying to deploy a new server and it is not issue certificates as it says that rate limit has reached. How long I need to wait till I get to issue new certificate? Is there anyway to reset this?
My domain is:esdump.apinf.io
There is no A nor AAAA record for esdump.apinf.io
Please show the complete error message (or letsenncrypt.log file - if one exists).
And the command you used.
If you don't provide the information requested, we can only guess what the problem is and also just guess at what might fix the problem we don't really understand...
Until the rate is not longer exceeded...
See: Rate Limits - Let's Encrypt to determine which limit you exceeded.
No. Only time can remove an exceeded rate limit.
You literally cut this out from your post (did you even bother to read it?):
sorry I put the error message here again
