My domain is: www.kinetix.digital & sub domain jenkins.dev.devo.kinetix.digital
My web server is nginx
My hosting provider is: namecheap
Im using nginx to serve jenkins on Vm with ubuntu. the sub domain jenkins.dev.devo.kinetix.digital is using the nginx serverto serve jenkins with http, but with https i get 404 not found
Below is my nginx configuration file:
upstream jenkins{
server 127.0.0.1:8080;
server{
listen 80;
server_name kinetix.digital;
ssl_certificate /etc/letsencrypt/live/kinetix.digital/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/kinetix.digital/privkey.pem;
access_log /var/log/nginx/jenkins.access.log;
error_log /var/log/nginx/jenkins.error.log;
proxy_buffers 16 64k;
proxy_buffer_size 128k;
proxy_pass http://jenkins;
proxy_next_upstream error timeout invalid_header http_500 http_502 http_503 http_504;
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto https;
server{
listen 80;
server_name jenkins.dev.devo.kinetix.digital;
ssl_certificate /etc/letsencrypt/live/jenkins.dev.devo.kinetix.digital/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/jenkins.dev.devo.kinetix.digital/privkey.pem;
proxy_redirect off;
I am positive the certs are valid and I haev entered them correctly in the config file, but appreciate I may have missed something
