Certificate works for www.example.com, but not for example.com
Hi, my domain is www.mpnpatientevent.com and it works with www.
Also it shows no error here https://www.ssllabs.com/ssltest/analyze.html?d=www.mpnpatientevent.com
As you may see on link above, it says
Subject www.mpnpatientevent.com
Fingerprint SHA256: d49a4e1b43dc432dea0a8d2c5a67b73f1170922959f9d275c452780eedb43734
Pin SHA256: ovDlKwe7e3f7/8/8p70Pf+KLmhZUVEf4Ck1QGy7RjRY=
Common names www.mpnpatientevent.com
Alternative names mpnpatientevent.com www.mpnpatientevent.com
So I believe that domain without www is also included in this certificate, right?
But it doesn’t work in browser without www.
Below is error I receive in Chrome browser:
NET::ERR_CERT_AUTHORITY_INVALID
Subject: ip-10-90-1-80
Issuer: ip-10-90-1-80
What is ip-10-90-1-80 ?
How to solve this error?
Please advise.
Hi @marchello
there are some bugs you should fix.
First - the non-www version uses a self signed certificate - https://check-your-website.server-daten.de/?q=mpnpatientevent.com
E=root@ip-10-90-1-80, CN=ip-10-90-1-80,
OU=SomeOrganizationalUnit, O=SomeOrganization,
L=SomeCity, S=SomeState, C=--
	04.12.2019
	03.12.2020
expires in 364 days	localhost, localhost.localdomain,
ip-10-90-1-80, ip-10-90-1-80.ec2.internal - 4 entries
It's an Apache, what says
apachectl -S
Add the non-www to your www vHost with an
ServerAlias mpnpatientevent.com
then again apachectl -S.
Second: Your redirect has a "missing /", so /.well-known/acme-challenge/random-filename is redirected to a not existing domain.
Third:
http://www.mpnpatientevent.com
	302
is a loop.
And you have created 9 certificates today.
JuergenAuer, thanks I will check with our admin tomorrow. Also it would be great to know how do we turn off using mentioned self-signed certificate. It’s linux ami (amazon ec2) and it is not too well-documented…
