I noticed that we were both completely unaware of some of the limitations of certbot with Windows-Apache, so I thought it a good idea to share my findings with you. I am very surprised at these current limitations:
Only standalone, manual, and webroot authentication plugins are supported. DNS authentication plugins will be available soon.
No installation plugins are supported. Apache and Nginx installation plugins will be available soon and an IIS installation plugin is under development.
Hi Again,
after looking into these articles the one you recomended i go from step 4 is too outdated from what it seems, as i followed the instructions there and thus nothing has changed?
Right so in Future reference for everyone who may have the same issue.
You have to configure httpd-ssl.conf to all the directories to your certificate, no virtual host editing was needed in my case.
This is for Xampp 3.2.4 running on Apache
Your DNS looks good. If you're using certbot, just create a certificate like you usually would, but use --cert-name finrhodweb.com -d "finrhodweb.com,www.finrhodweb.com" (with the quotes).
