snapto.co.uk
scl enable python27 “./certbot-auto certonly --force-renewal --rsa-key-size 4096 --email hostmaster@snapto.co.uk --agree-tos -w /home/snapto/public_html/ -d snapto.co.uk -d www.snapto.co.uk -d mail.snapto.co.uk -d server.snapto.co.uk --authenticator webroot”
Failed authorization procedure. server.snapto.co.uk (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://server.snapto.co.uk/.well-known/acme-challenge/TOEUbg0KAPf9UxFipyw8PbGIJHAuHA29ffBTNOgylQU:1
Apache 2.2.15
CentOS 6.9
Yes
Virtualmin 6.02
snapto.co.uk is the main domain name of the server and is set to use server.snapto.co.uk
This has been working fine for over a year, this error only appeared with that laest renewal attempt. The other snapto.co.uk domain can renew fine as well as all other domains on the site. The web root path is the same for all the snapto.co.uk domains and is reachable by http the only difference is that server.snapto.co.uk is set as the FQDN of the server. Sanptoc.o.uk is set as the default virtual server for the server main IP
The cert for gardendesignershertfordshire.co.uk was only added recently after the previous renewal for snapto.co.uk
The details of the cert show correctly see enclosed screenshot and the cert still works. The marked as trusted for gardendesignershertfordshire.co.uk I can only see in Safari.
Questions
- What generates the marked as trusted for ? Is this read locally from the cert files ?
- If when generating a cert using webroot and the webroot path is wrong will it still gernate a certificate i.e. in case I set the webroot using snapto path when generating the cert for gardendesignershertfordshire.co.uk which is highly unlikely but possible hence the potential reason for that domain showing ?
Solution
- Would revoking the snapto.co.uk cert, deleteing then re-obtaining a new cert likely to work ?
- Any other ideas ?
