Certificate renwal issue
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (https://gamify.arrkgroup.com), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: gamify.arrkgroup.com/
I ran this command: sh /usr/local/bin/renewcert.sh
Notifying user: The following certificates are not due for renewal yet:
Notifying user: /etc/letsencrypt/live/khushi.arrkgroup.com/fullchain.pem expires on 2024-05-02 (skipped)
/etc/letsencrypt/live/gamify.arrkgroup.com/fullchain.pem (failure)
/etc/letsencrypt/live/gamifyapi.arrkgroup.com/fullchain.pem (failure)
Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
Exiting abnormally:
File "/usr/bin/certbot", line 9, in
load_entry_point('certbot==1.11.0', 'console_scripts', 'certbot')()
File "/usr/lib/python2.7/site-packages/certbot/main.py", line 15, in main
File "/usr/lib/python2.7/site-packages/certbot/_internal/main.py", line 1421, in main
File "/usr/lib/python2.7/site-packages/certbot/_internal/main.py", line 1318, in renew
renewal.handle_renewal_request(config)
File "/usr/lib/python2.7/site-packages/certbot/_internal/renewal.py", line 497, in handle_renewal_request
len(renew_failures), len(parse_failures)))
Error: 2 renew failure(s), 0 parse failure(s)
    Domain: gamify.arrkgroup.com
    Type: connection
    Detail: 59.163.23.110: Fetching
    http://gamify.arrkgroup.com/.well-known/acme-challenge/aNVIiAEL4aBkvOtBQcFdcLJjDslD5aDwa8e5uKQzl6Y:
    Domain: gamifyapi.arrkgroup.com
    Type: connection
    http://gamifyapi.arrkgroup.com/.well-known/acme-challenge/A4DUqqR0odADHuz5kNS6tGv1iTFpQigINXx-b1iS1H0:
The operating system my web server runs on is (include version): Cent os 7
Have you closed port 80 since you originally got that cert?
Because the HTTP request from the Let's Encrypt server is not able to reach your server.
The Let's Debug test site is helpful to test as you make changes to restore HTTP access. You must have had it working when you originally got your cert. Check any network config and check the IP address is still correct.
I see the same results as Let's Debug got for @MikeMcQ
$ nmap -Pn -p80,443 gamify.arrkgroup.com
Starting Nmap 7.80 ( https://nmap.org ) at 2024-03-08 23:38 UTC
Nmap scan report for gamify.arrkgroup.com (59.163.23.110)
Host is up.
rDNS record for 59.163.23.110: 59.163.23.110.static.vsnl.net.in
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.99 seconds
