https://glinithai.ddns.net
certbot renew -q --pre-hook “service apache2 stop” --post-hook "service apache2 start"
Here is only the last part of the logfile:
2017-12-07 07:35:08,210:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:
Domain: glinithai.ddns.net
Type: connection
Detail: Timeout
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you’re using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
2017-12-07 07:35:08,211:INFO:certbot.auth_handler:Cleaning up challenges
2017-12-07 07:35:08,365:WARNING:certbot.renewal:Attempting to renew cert (glinithai.ddns.net) from /etc/letsencrypt/renewal/glinithai.ddns.net.conf produced an unexpected error: Failed authorization procedure. glinithai.ddns.net (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout. Skipping.
2017-12-07 07:35:08,365:DEBUG:certbot.renewal:Traceback was:
File “/usr/lib/python2.7/dist-packages/certbot/renewal.py”, line 425, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 743, in renew_cert
_get_and_save_cert(le_client, config, lineage=lineage)
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 80, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File “/usr/lib/python2.7/dist-packages/certbot/renewal.py”, line 297, in renew_cert
new_certr, new_chain, new_key, _ = le_client.obtain_certificate(domains)
File “/usr/lib/python2.7/dist-packages/certbot/client.py”, line 318, in obtain_certificate
self.config.allow_subset_of_names)
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 81, in get_authorizations
self._respond(resp, best_effort)
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 138, in _respond
self._poll_challenges(chall_update, best_effort)
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 202, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. glinithai.ddns.net (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
2017-12-07 07:35:08,366:ERROR:certbot.renewal:All renewal attempts failed. The following certs could not be renewed:
2017-12-07 07:35:08,366:ERROR:certbot.renewal: /etc/letsencrypt/live/glinithai.ddns.net/fullchain.pem (failure)
2017-12-07 07:35:08,366:INFO:certbot.hooks:Running post-hook command: service apache2 start
2017-12-07 07:35:09,537:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.19.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 861, in main
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 797, in renew
renewal.handle_renewal_request(config)
File “/usr/lib/python2.7/dist-packages/certbot/renewal.py”, line 443, in handle_renewal_request
len(renew_failures), len(parse_failures)))
Error: 1 renew failure(s), 0 parse failure(s)
Apache Version Apache/2.4.18 (Ubuntu)
Apache API Version 20120211
Ubuntu 16.04
Linux my-nas 4.4.0-101-generic #124-Ubuntu SMP Fri Nov 10 18:29:59 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Private Server ay home
no
I set up this webserver in April this year and decided to use lets encrypt for certificates, everything worked fine, until some days ago the automatic renewal don’t work anymore. The certificate is still valid until January 3rd. But should be renewed in the next days.
The site is accessable from outside, I don’t know why this happens.
One thing I realized, I’m living in Thailand and the standard port 443 is not accessible from outside Thailand.
So, I configured a second port to access https, but I can’t imagine this is the reason for my problem.
Thanks in advance for all help
