Certificate renew failing - Hashicorp vault
My domain is: vault.businessapplications.co.nz
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/vault.businessapplications.co.nz.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for vault.businessapplications.co.nz
Waiting for verification…
Attempting to renew cert (vault.businessapplications.co.nz) from /etc/letsencrypt/renewal/vault.businessapplications.co.nz.conf produced an unexpected error: Failed authorization procedure. vault.businessapplications.co.nz (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://vault.businessapplications.co.nz/.well-known/acme-challenge/C_HQw8LqQc7LNKH09uSSBBNSVivX7LbaSMb3m_wrrjE: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/vault.businessapplications.co.nz/fullchain.pem (failure)
    Domain: vault.businessapplications.co.nz
    Type: connection
    Detail: Fetching
(hashicorp vault) Vault v0.10.1 (‘756fdc4587350daf1c65b93647b2cc31a6f119cd’)
Ubuntu 16.04,64 bit version
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): no ui enabled for vault.certs generated using standalone, certonly methods
Hi @johnpaultthomas
you have a dns-entry vault.businessapplications.co.nz -> ip-address, this is good.
But my browser can't connect your domain.
Is there a running webserver? Or a firewall that blocks?
I am not running a webserver.But i just enabled a ngix webserver for test purpose.try again pls
I need to disable this before running the cert renew again.Otherwise it will complain unable to use port 80
As expected it was a firewall issue
Yep, now you have a new certificate, created today.
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:vault.businessapplications.co.nz&lu=cert_search
