Certificate renew error I can not renew by nginx nor stand alone
My domain is: datacook.org
I ran this command: sudo certbot --nginx certonly
Failed authorization procedure. www.datacook.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.datacook.org/.well-known/acme-challenge/0Nb6t_dBDPxKBovlHHYEesgg67DQGWzFS8CvYXHvHyk [2607:f1c0:100f:f000::234]: 204
My web server is (include version): node js
The operating system my web server runs on is (include version): ununtu 14.4
My hosting provider, if applicable, is: AWS
I can login to a root shell on my machine (yes or no, or I don’t know): YES
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Your domain’s IPv4 and IPv6 addresses point to different servers.
Make sure they point to the same server, or get rid of the one address that is pointing to the wrong server.
Thanks for pointing out. I checked AAAA value and confirmed it had wrong value. It has been updated and fixed the issue.
