Hi there,
for my life I just can’t find the error. The machine in question does not run a webservice, so port 80 (and 443) are both free. From the debug-log I can see it is bound to the IPv6 address, but I have no AAAA record set (only CNAME to dyndns-adress -> to my IP).
When I bind some other program to port 80 on that machine (eg via nc), the portforward clearly works.
I have a debug-log of the successfull creation of the certificates (approx 2 months ago) and a debug log of a lot of failed tries to renew the certificate, if this helps.
Any help / hint is appreciated.
unifi.seconet.de
certbot renew
Processing /etc/letsencrypt/renewal/unifi.seconet.de.conf
http-01 challenge for unifi.seconet.de
Waiting for verification…
Attempting to renew cert (unifi.seconet.de) from /etc/letsencrypt/renewal/unifi.seconet.de.conf produced an unexpected error: Failed authorization procedure. unifi.seconet.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://unifi.seconet.de/.well-known/acme-challenge/G-Rvam5D_D9WSBgPTFZ1oz2rY2igmFkRSsfp973ULEw: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/unifi.seconet.de/fullchain.pem (failure)
Domain: unifi.seconet.de
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
none (standalone)
Debian Stretch 9.11
n/a
or certbot-auto --version
if you’re using Certbot):
certbot 0.28.0
