Yes, I think you probably will need to delete the /etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/
directory.
Thanks now certbot register worked
Originally you obtained your certificate using the --standalone
plugin. This only works if you're not already running a server on port 80.
Based on that error message, you do have something running on port 80.
You will need to either:
- Pick a different Certbot plugin to renew your certificate
- Change your Certbot command so that it stops server that is running on port 80, renews the certificate, then starts the server up again
Thanks
