Certificate not issued for domainname.wedding
My domain is: https://montsaintmichel.wedding/
I ran this command: (nside crontab)
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
0 */12 * * * root test -x /usr/bin/certbot && perl -e β€˜sleep int(rand(3600))’ && certbot -q renew
It produced this output: no certificate update, while for other domain, the same command is working (example : oloupstmichel.fr)
My web server is (include version): Apache/2.4.7
The operating system my web server runs on is (include version): Ubuntu 14.04.5 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.22.2
Hi @Tank
please don't run Certbot with the -q parameter. That hides too much.
What's the error Certbot shows?
Your certificate ( montsaintmichel.wedding - Make your website better - DNS, redirects, mixed content, certificates ):
CN=montsaintmichel.wedding
	05.02.2019
	06.05.2019
177 days expired	montsaintmichel.wedding, www.montsaintmichel.wedding - 2 entries
is 177 days expired, so it's an old problem.
And your configuration is buggy, there is a redirect to a not existing domain:
β€’ http://montsaintmichel.wedding/ 178.79.166.197 302 https://www.montsaintmichel.wedding Html is minified: 100,00 % 0.063 E
β€’ http://www.montsaintmichel.wedding/ 178.79.166.197 302 https://www.montsaintmichel.wedding Html is minified: 100,00 % 0.064 A
β€’ https://montsaintmichel.wedding/ 178.79.166.197 GZip used - 3726 / 21469 - 82,64 % Inline-JavaScript (βˆ‘/total): 0/0 Inline-CSS (βˆ‘/total): 0/0 200 Html is minified: 127,08 % 3.513 N
Certificate error: RemoteCertificateChainErrors
β€’ https://www.montsaintmichel.wedding/ 178.79.166.197 GZip used - 3726 / 21469 - 82,64 % Inline-JavaScript (βˆ‘/total): 0/0 Inline-CSS (βˆ‘/total): 0/0 200 Html is minified: 127,08 % 3.233 N
β€’ https://www.montsaintmichel.wedding GZip used - 3726 / 21469 - 82,64 % Inline-JavaScript (βˆ‘/total): 0/0 Inline-CSS (βˆ‘/total): 0/0 200 Html is minified: 127,08 % 3.297 N
β€’ http://montsaintmichel.wedding/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 178.79.166.197 Inline-JavaScript (βˆ‘/total): 0/0 Inline-CSS (βˆ‘/total): 0/0 302 https://www.montsaintmichel.wedding.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de Html is minified: 100,00 % 0.063 E
Visible Content: Found The document has moved here .
β€’ http://www.montsaintmichel.wedding/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 178.79.166.197 Inline-JavaScript (βˆ‘/total): 0/0 Inline-CSS (βˆ‘/total): 0/0 302 https://www.montsaintmichel.wedding.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de Html is minified: 100,00 % 0.063 A
β€’ https://www.montsaintmichel.wedding.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de -1 0.047 R
NameResolutionFailure - The remote name could not be resolved: 'www.montsaintmichel.wedding.well-known'
Happens, if your redirect rule has a "missing slash".
Your first redirect has the same problem:
http://montsaintmichel.wedding/ -> https://www.montsaintmichel.wedding
so if a subfolder is redirected, that's a not existing domain name.
Thank you very much, it was the missing slash error. Everything is working again!
BR,
Tank
