Hello,
Through my internet provider “freebox”, I created the domain name: ma-box.freeboxos.fr.
Since one month the certificate is still not active!
Can you check why the certificate is not generated and intervene to remedy the situation
Thank you
CN=mon-domaine.eu, OU=PositiveSSL,
OU=Domain Control Validated
14.08.2019
02.05.2020
expires in 241 days mon-domaine.eu, www.mon-domaine.eu - 2 entries
Is this a home server? So you have to install the certificate?
What's your environment?
The operating system my web server runs on is (include version): ?
My hosting provider, if applicable, is: freebox.fr
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes “freeboxos” provided by my internet provider: free.fr
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): ?
You will understand it is not me but my internet service provider who is applying for a certificate.
I thought the lock was coming from Lets’Encrypt, please tell me if the problem can be solved by me or Lets’Encrypt or if I have to turn to free.fr.
Thank you
Let’s Encrypt certificates are always generated automatically, by software talking to software, with no humans in the loop. Typically, certificates are generated and valid in just a few seconds.
In this case, it appears that your device is not successfully installing the certificates after obtaining them, so you should probably talk to the people who are responsible for supporting the device (which may be the ISP).
