acme.sh --renew --standalone -d dragonosman.dynu.net --dns dns_dynu --debug
And got this result:
[Sat Jun 15 18:31:19 STD 2019] Lets find script dir.
[Sat Jun 15 18:31:19 STD 2019] _SCRIPT_='/mnt/c/Users/Osman/acme.sh/acme.sh'
[Sat Jun 15 18:31:20 STD 2019] _script='/mnt/c/Users/Osman/acme.sh/acme.sh'
[Sat Jun 15 18:31:20 STD 2019] _script_home='/mnt/c/Users/Osman/acme.sh'
[Sat Jun 15 18:31:20 STD 2019] Using default home:/home/osman/.acme.sh
[Sat Jun 15 18:31:20 STD 2019] Using config home:/home/osman/.acme.sh
https://github.com/Neilpang/acme.sh
v2.8.1
[Sat Jun 15 18:31:20 STD 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Sat Jun 15 18:31:21 STD 2019] DOMAIN_PATH='/home/osman/.acme.sh/dragonosman.dynu.net'
[Sat Jun 15 18:31:21 STD 2019] Renew: 'dragonosman.dynu.net'
[Sat Jun 15 18:31:21 STD 2019] Le_API='https://acme-v01.api.letsencrypt.org/directory'
[Sat Jun 15 18:31:21 STD 2019] Using config home:/home/osman/.acme.sh
[Sat Jun 15 18:31:21 STD 2019] ACME_DIRECTORY='https://acme-v01.api.letsencrypt.org/directory'
[Sat Jun 15 18:31:22 STD 2019] _main_domain='dragonosman.dynu.net'
[Sat Jun 15 18:31:22 STD 2019] _alt_domains='no'
[Sat Jun 15 18:31:22 STD 2019] Using ACME_DIRECTORY: https://acme-v01.api.letsencrypt.org/directory
[Sat Jun 15 18:31:22 STD 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Sat Jun 15 18:31:22 STD 2019] GET
[Sat Jun 15 18:31:22 STD 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Sat Jun 15 18:31:22 STD 2019] timeout=
[Sat Jun 15 18:31:23 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:24 STD 2019] ret='0'
[Sat Jun 15 18:31:25 STD 2019] ACME_KEY_CHANGE='https://acme-v01.api.letsencrypt.org/acme/key-change'
[Sat Jun 15 18:31:25 STD 2019] ACME_NEW_AUTHZ='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Sat Jun 15 18:31:25 STD 2019] ACME_NEW_ORDER='https://acme-v01.api.letsencrypt.org/acme/new-cert'
[Sat Jun 15 18:31:25 STD 2019] ACME_NEW_ACCOUNT='https://acme-v01.api.letsencrypt.org/acme/new-reg'
[Sat Jun 15 18:31:25 STD 2019] ACME_REVOKE_CERT='https://acme-v01.api.letsencrypt.org/acme/revoke-cert'
[Sat Jun 15 18:31:25 STD 2019] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf'
[Sat Jun 15 18:31:25 STD 2019] ACME_NEW_NONCE
[Sat Jun 15 18:31:25 STD 2019] ACME_VERSION
[Sat Jun 15 18:31:25 STD 2019] Le_NextRenewTime
[Sat Jun 15 18:31:25 STD 2019] _on_before_issue
[Sat Jun 15 18:31:25 STD 2019] _chk_main_domain='dragonosman.dynu.net'
[Sat Jun 15 18:31:25 STD 2019] _chk_alt_domains
[Sat Jun 15 18:31:25 STD 2019] Le_LocalAddress
[Sat Jun 15 18:31:25 STD 2019] d='dragonosman.dynu.net'
[Sat Jun 15 18:31:25 STD 2019] Check for domain='dragonosman.dynu.net'
[Sat Jun 15 18:31:25 STD 2019] _currentRoot='no'
[Sat Jun 15 18:31:25 STD 2019] Standalone mode.
[Sat Jun 15 18:31:25 STD 2019] _checkport='80'
[Sat Jun 15 18:31:25 STD 2019] _checkaddr
[Sat Jun 15 18:31:26 STD 2019] Using: ss
[Sat Jun 15 18:31:26 STD 2019] d
[Sat Jun 15 18:31:26 STD 2019] _saved_account_key_hash is not changed, skip register account.
[Sat Jun 15 18:31:26 STD 2019] Read key length:
[Sat Jun 15 18:31:26 STD 2019] _createcsr
[Sat Jun 15 18:31:26 STD 2019] Single domain='dragonosman.dynu.net'
[Sat Jun 15 18:31:26 STD 2019] Getting domain auth token for each domain
[Sat Jun 15 18:31:26 STD 2019] d='dragonosman.dynu.net'
[Sat Jun 15 18:31:26 STD 2019] Getting webroot for domain='dragonosman.dynu.net'
[Sat Jun 15 18:31:26 STD 2019] _w='no'
[Sat Jun 15 18:31:26 STD 2019] _currentRoot='no'
[Sat Jun 15 18:31:26 STD 2019] Getting new-authz for domain='dragonosman.dynu.net'
[Sat Jun 15 18:31:26 STD 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Sat Jun 15 18:31:26 STD 2019] Try new-authz for the 0 time.
[Sat Jun 15 18:31:26 STD 2019] url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Sat Jun 15 18:31:26 STD 2019] payload='{"resource": "new-authz", "identifier": {"type": "dns", "value": "dragonosman.dynu.net"}}'
[Sat Jun 15 18:31:26 STD 2019] RSA key
[Sat Jun 15 18:31:26 STD 2019] GET
[Sat Jun 15 18:31:26 STD 2019] url='https://acme-v01.api.letsencrypt.org/directory'
[Sat Jun 15 18:31:26 STD 2019] timeout=
[Sat Jun 15 18:31:26 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:28 STD 2019] ret='0'
[Sat Jun 15 18:31:28 STD 2019] POST
[Sat Jun 15 18:31:28 STD 2019] _post_url='https://acme-v01.api.letsencrypt.org/acme/new-authz'
[Sat Jun 15 18:31:28 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:30 STD 2019] _ret='0'
[Sat Jun 15 18:31:30 STD 2019] code='201'
[Sat Jun 15 18:31:30 STD 2019] The new-authz request is ok.
[Sat Jun 15 18:31:30 STD 2019] entry='"type":"http-01","status":"pending","uri":"https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139","token":"ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0"'
[Sat Jun 15 18:31:30 STD 2019] token='ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0'
[Sat Jun 15 18:31:30 STD 2019] uri='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:30 STD 2019] keyauthorization='ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0.5pNh6OaO0_wXH-sDCEAJauqu7GIQu3epS31RM9mgIuk'
[Sat Jun 15 18:31:30 STD 2019] dvlist='dragonosman.dynu.net#ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0.5pNh6OaO0_wXH-sDCEAJauqu7GIQu3epS31RM9mgIuk#https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139#http-01#no'
[Sat Jun 15 18:31:30 STD 2019] vlist='dragonosman.dynu.net#ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0.5pNh6OaO0_wXH-sDCEAJauqu7GIQu3epS31RM9mgIuk#https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139#http-01#no,'
[Sat Jun 15 18:31:30 STD 2019] d='dragonosman.dynu.net'
[Sat Jun 15 18:31:30 STD 2019] ok, let's start to verify
[Sat Jun 15 18:31:31 STD 2019] Verifying: dragonosman.dynu.net
[Sat Jun 15 18:31:31 STD 2019] d='dragonosman.dynu.net'
[Sat Jun 15 18:31:31 STD 2019] keyauthorization='ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0.5pNh6OaO0_wXH-sDCEAJauqu7GIQu3epS31RM9mgIuk'
[Sat Jun 15 18:31:31 STD 2019] uri='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:31 STD 2019] _currentRoot='no'
[Sat Jun 15 18:31:31 STD 2019] Standalone mode server
[Sat Jun 15 18:31:31 STD 2019] content='ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0.5pNh6OaO0_wXH-sDCEAJauqu7GIQu3epS31RM9mgIuk'
[Sat Jun 15 18:31:31 STD 2019] ncaddr
[Sat Jun 15 18:31:31 STD 2019] startserver: 22
[Sat Jun 15 18:31:31 STD 2019] Le_HTTPPort='80'
[Sat Jun 15 18:31:31 STD 2019] Le_Listen_V4
[Sat Jun 15 18:31:31 STD 2019] Le_Listen_V6
[Sat Jun 15 18:31:31 STD 2019] _content_len='87'
[Sat Jun 15 18:31:31 STD 2019] _NC='socat TCP-LISTEN:80,crlf,reuseaddr,fork'
2019/06/15 18:31:31 socat[537] E bind(5, {AF=2 0.0.0.0:80}, 16): Permission denied
[Sat Jun 15 18:31:32 STD 2019] serverproc='537'
[Sat Jun 15 18:31:32 STD 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:32 STD 2019] payload='{"resource": "challenge", "type": "http-01", "keyAuthorization": "ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0.5pNh6OaO0_wXH-sDCEAJauqu7GIQu3epS31RM9mgIuk"}'
[Sat Jun 15 18:31:32 STD 2019] POST
[Sat Jun 15 18:31:32 STD 2019] _post_url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:32 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:39 STD 2019] _ret='0'
[Sat Jun 15 18:31:39 STD 2019] code='202'
[Sat Jun 15 18:31:39 STD 2019] sleep 2 secs to verify
[Sat Jun 15 18:31:41 STD 2019] checking
[Sat Jun 15 18:31:41 STD 2019] GET
[Sat Jun 15 18:31:41 STD 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:41 STD 2019] timeout=
[Sat Jun 15 18:31:42 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:42 STD 2019] ret='0'
[Sat Jun 15 18:31:43 STD 2019] Pending
[Sat Jun 15 18:31:43 STD 2019] sleep 2 secs to verify
[Sat Jun 15 18:31:45 STD 2019] checking
[Sat Jun 15 18:31:45 STD 2019] GET
[Sat Jun 15 18:31:45 STD 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:45 STD 2019] timeout=
[Sat Jun 15 18:31:45 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:46 STD 2019] ret='0'
[Sat Jun 15 18:31:46 STD 2019] Pending
[Sat Jun 15 18:31:46 STD 2019] sleep 2 secs to verify
[Sat Jun 15 18:31:48 STD 2019] checking
[Sat Jun 15 18:31:48 STD 2019] GET
[Sat Jun 15 18:31:48 STD 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:48 STD 2019] timeout=
[Sat Jun 15 18:31:48 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:49 STD 2019] ret='0'
[Sat Jun 15 18:31:49 STD 2019] Pending
[Sat Jun 15 18:31:49 STD 2019] sleep 2 secs to verify
[Sat Jun 15 18:31:51 STD 2019] checking
[Sat Jun 15 18:31:51 STD 2019] GET
[Sat Jun 15 18:31:51 STD 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:51 STD 2019] timeout=
[Sat Jun 15 18:31:51 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:52 STD 2019] ret='0'
[Sat Jun 15 18:31:52 STD 2019] dragonosman.dynu.net:Verify error:Fetching http://dragonosman.dynu.net/.well-known/acme-challenge/ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0: Timeout during connect (likely firewall problem)
[Sat Jun 15 18:31:52 STD 2019] Debug: get token url.
[Sat Jun 15 18:31:52 STD 2019] GET
[Sat Jun 15 18:31:52 STD 2019] url='http://dragonosman.dynu.net/.well-known/acme-challenge/ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0'
[Sat Jun 15 18:31:52 STD 2019] timeout=1
[Sat Jun 15 18:31:52 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g --connect-timeout 1'
<html><head><script language='javascript'>
parent.location='login.html'
</script></head><body></body></html>HTTP/1.1 404 Not Found
Server: micro_httpd
Cache-Control: no-cache
Date: Sat, 15 Jun 2019 18:31:54 GMT
Content-Type: text/html
Connection: close
<HTML><HEAD><TITLE>404 Not Found</TITLE></HEAD>
<BODY BGCOLOR="#cc9999"><H4>404 Not Found</H4>
File not found.
<HR>
<ADDRESS><A HREF="http://www.acme.com/software/micro_httpd/">micro_httpd</A></ADDRESS>
</BODY></HTML>
[Sat Jun 15 18:31:53 STD 2019] ret='0'
[Sat Jun 15 18:31:53 STD 2019] Skip for removelevel:
[Sat Jun 15 18:31:53 STD 2019] pid='537'
/mnt/c/Users/Osman/acme.sh/acme.sh: 2114: kill: No such process
[Sat Jun 15 18:31:53 STD 2019] No need to restore nginx, skip.
[Sat Jun 15 18:31:53 STD 2019] _clearupdns
[Sat Jun 15 18:31:53 STD 2019] dns_entries
[Sat Jun 15 18:31:53 STD 2019] skip dns.
[Sat Jun 15 18:31:53 STD 2019] _on_issue_err
[Sat Jun 15 18:31:53 STD 2019] Please add '--debug' or '--log' to check more details.
[Sat Jun 15 18:31:53 STD 2019] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh
[Sat Jun 15 18:31:53 STD 2019] url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:53 STD 2019] payload='{"resource": "challenge", "type": "", "keyAuthorization": "ATDEybvL1txhJYACcD8dFZlc1tA8ILCGFI8b0t8SSm0.5pNh6OaO0_wXH-sDCEAJauqu7GIQu3epS31RM9mgIuk"}'
[Sat Jun 15 18:31:53 STD 2019] POST
[Sat Jun 15 18:31:53 STD 2019] _post_url='https://acme-v01.api.letsencrypt.org/acme/challenge/Jpyyb5wCjNnZsLxvyjFUrlyB6mF0Aq53hb2F4PAc-Nc/17105589139'
[Sat Jun 15 18:31:53 STD 2019] _CURL='curl -L --silent --dump-header /home/osman/.acme.sh/http.header -g '
[Sat Jun 15 18:31:55 STD 2019] _ret='0'
[Sat Jun 15 18:31:55 STD 2019] code='400'
[Sat Jun 15 18:31:55 STD 2019] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.0g 2 Nov 2017
apache:
apache doesn't exists.
nginx:
nginx doesn't exists.
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
Usage:
socat [options] <bi-address> <bi-address>
options:
-V print version and feature information to stdout, and exit
-h|-? print a help text describing command line options and addresses
-hh like -h, plus a list of all common address option names
-hhh like -hh, plus a list of all available address option names
-d increase verbosity (use up to 4 times; 2 are recommended)
-D analyze file descriptors before loop
-ly[facility] log to syslog, using facility (default is daemon)
-lf<logfile> log to file
-ls log to stderr (default if no other log)
-lm[facility] mixed log mode (stderr during initialization, then syslog)
-lp<progname> set the program name used for logging
-lu use microseconds for logging timestamps
-lh add hostname to log messages
-v verbose data traffic, text
-x verbose data traffic, hexadecimal
-b<size_t> set data buffer size (8192)
-s sloppy (continue on error)
-t<timeout> wait seconds before closing second channel
-T<timeout> total inactivity timeout in seconds
-u unidirectional mode (left to right)
-U unidirectional mode (right to left)
-g do not check option groups
-L <lockfile> try to obtain lock, or fail
-W <lockfile> try to obtain lock, or wait
-4 prefer IPv4 if version is not explicitly specified
-6 prefer IPv6 if version is not explicitly specified
bi-address:
pipe[,<opts>] groups=FD,FIFO
<single-address>!!<single-address>
<single-address>
single-address:
<address-head>[,<opts>]
address-head:
abstract-client:<filename> groups=FD,SOCKET,RETRY,UNIX
abstract-connect:<filename> groups=FD,SOCKET,RETRY,UNIX
abstract-listen:<filename> groups=FD,SOCKET,LISTEN,CHILD,RETRY,UNIX
abstract-recv:<filename> groups=FD,SOCKET,RETRY,UNIX
abstract-recvfrom:<filename> groups=FD,SOCKET,CHILD,RETRY,UNIX
abstract-sendto:<filename> groups=FD,SOCKET,RETRY,UNIX
create:<filename> groups=FD,REG,NAMED
exec:<command-line> groups=FD,FIFO,SOCKET,EXEC,FORK,TERMIOS,PTY,PARENT,UNIX
fd:<num> groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
gopen:<filename> groups=FD,FIFO,CHR,BLK,REG,SOCKET,NAMED,OPEN,TERMIOS,UNIX
interface:<interface> groups=FD,SOCKET
ip-datagram:<host>:<protocol> groups=FD,SOCKET,RANGE,IP4,IP6
ip-recv:<protocol> groups=FD,SOCKET,RANGE,IP4,IP6
ip-recvfrom:<protocol> groups=FD,SOCKET,CHILD,RANGE,IP4,IP6
ip-sendto:<host>:<protocol> groups=FD,SOCKET,IP4,IP6
ip4-datagram:<host>:<protocol> groups=FD,SOCKET,RANGE,IP4
ip4-recv:<protocol> groups=FD,SOCKET,RANGE,IP4
ip4-recvfrom:<protocol> groups=FD,SOCKET,CHILD,RANGE,IP4
ip4-sendto:<host>:<protocol> groups=FD,SOCKET,IP4
ip6-datagram:<host>:<protocol> groups=FD,SOCKET,RANGE,IP6
ip6-recv:<protocol> groups=FD,SOCKET,RANGE,IP6
ip6-recvfrom:<protocol> groups=FD,SOCKET,CHILD,RANGE,IP6
ip6-sendto:<host>:<protocol> groups=FD,SOCKET,IP6
open:<filename> groups=FD,FIFO,CHR,BLK,REG,NAMED,OPEN,TERMIOS
openssl:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,OPENSSL
openssl-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,TCP,OPENSSL
pipe:<filename> groups=FD,FIFO,NAMED,OPEN
proxy:<proxy-server>:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,HTTP
pty groups=FD,NAMED,TERMIOS,PTY
sctp-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,SCTP
sctp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,SCTP
sctp4-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,SCTP
sctp4-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,SCTP
sctp6-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP6,SCTP
sctp6-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP6,SCTP
socket-connect:<domain>:<protocol>:<remote-address> groups=FD,SOCKET,CHILD,RETRY
socket-datagram:<domain>:<type>:<protocol>:<remote-address> groups=FD,SOCKET,RANGE
socket-listen:<domain>:<protocol>:<local-address> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE
socket-recv:<domain>:<type>:<protocol>:<local-address> groups=FD,SOCKET,RANGE
socket-recvfrom:<domain>:<type>:<protocol>:<local-address> groups=FD,SOCKET,CHILD,RANGE
socket-sendto:<domain>:<type>:<protocol>:<remote-address> groups=FD,SOCKET
socks4:<socks-server>:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,SOCKS4
socks4a:<socks-server>:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP,SOCKS4
stderr groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
stdin groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
stdio groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
stdout groups=FD,FIFO,CHR,BLK,REG,SOCKET,TERMIOS,UNIX,IP4,IP6,UDP,TCP,SCTP
system:<shell-command> groups=FD,FIFO,SOCKET,EXEC,FORK,TERMIOS,PTY,PARENT,UNIX
tcp-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,IP6,TCP
tcp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,IP6,TCP
tcp4-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP4,TCP
tcp4-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP4,TCP
tcp6-connect:<host>:<port> groups=FD,SOCKET,CHILD,RETRY,IP6,TCP
tcp6-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RETRY,RANGE,IP6,TCP
tun[:<ip-addr>/<bits>] groups=FD,CHR,NAMED,OPEN,INTERFACE
udp-connect:<host>:<port> groups=FD,SOCKET,IP4,IP6,UDP
udp-datagram:<host>:<port> groups=FD,SOCKET,RANGE,IP4,IP6,UDP
udp-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP4,IP6,UDP
udp-recv:<port> groups=FD,SOCKET,RANGE,IP4,IP6,UDP
udp-recvfrom:<port> groups=FD,SOCKET,CHILD,RANGE,IP4,IP6,UDP
udp-sendto:<host>:<port> groups=FD,SOCKET,IP4,IP6,UDP
udp4-connect:<host>:<port> groups=FD,SOCKET,IP4,UDP
udp4-datagram:<remote-address>:<port> groups=FD,SOCKET,RANGE,IP4,UDP
udp4-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP4,UDP
udp4-recv:<port> groups=FD,SOCKET,RANGE,IP4,UDP
udp4-recvfrom:<host>:<port> groups=FD,SOCKET,CHILD,RANGE,IP4,UDP
udp4-sendto:<host>:<port> groups=FD,SOCKET,IP4,UDP
udp6-connect:<host>:<port> groups=FD,SOCKET,IP6,UDP
udp6-datagram:<host>:<port> groups=FD,SOCKET,RANGE,IP6,UDP
udp6-listen:<port> groups=FD,SOCKET,LISTEN,CHILD,RANGE,IP6,UDP
udp6-recv:<port> groups=FD,SOCKET,RANGE,IP6,UDP
udp6-recvfrom:<port> groups=FD,SOCKET,CHILD,RANGE,IP6,UDP
udp6-sendto:<host>:<port> groups=FD,SOCKET,IP6,UDP
unix-client:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
unix-connect:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
unix-listen:<filename> groups=FD,SOCKET,NAMED,LISTEN,CHILD,RETRY,UNIX
unix-recv:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
unix-recvfrom:<filename> groups=FD,SOCKET,NAMED,CHILD,RETRY,UNIX
unix-sendto:<filename> groups=FD,SOCKET,NAMED,RETRY,UNIX
It’s still getting a timeout trying to make an HTTP request. What do I do now?
