My domain is: chelsealeventhal.net and www.chelsealeventhal.net
I ran this command: sudo certbot certonly -a manual -d chelsealeventhal.net -d www.chelsealeventhal.net --email my@email.address
http-01 challenge for chelsealeventhal.net
http-01 challenge for www.chelsealeventhal.net
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: y
Create a file containing just this data:
Gq3Toc6P8hakROhbROKQKNzXSrCbtmS1QoaagCBQyRY.08ZKBKx1sRRfg5qxisMN-eD4U8K4TpbXiWefU1Zh6GY
http://chelsealeventhal.net/.well-known/acme-challenge/Gq3Toc6P8hakROhbROKQKNzXSrCbtmS1QoaagCBQyRY
Press Enter to Continue
f4VyJKpqTU8bGSp09ym6sQWYmTmYD1Ne6yLB-KYw6Ec.08ZKBKx1sRRfg5qxisMN-eD4U8K4TpbXiWefU1Zh6GY
Waiting for verification…
Resetting dropped connection: acme-v01.api.letsencrypt.org
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/chelsealeventhal.net/fullchain.pem
/etc/letsencrypt/live/chelsealeventhal.net/privkey.pem
Your cert will expire on 2019-06-26. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
“certbot renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My web server is (include version): Website is hosted on gitlab.com
The operating system my web server runs on is (include version): ?
My hosting provider, if applicable, is: gitlab.com
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): No. We are using a separate service for custom domain hosting though.
or certbot-auto --version
if you’re using Certbot): certbot 0.23.0
So I thought I was creating 2 certificates for the two domains (which both point to the same IP address though). In the letsencrypt directory that was created, I can find only one of the domains. Or am I supposed to use the certificate and key for both of them?
Thanks a lot!
