In addition to what @Patches said, you already issued 6 certificates for your domain today:
CRT ID DOMAIN (CN) VALID FROM VALID TO EXPIRES IN SANs
318485641 bigbadwolf.productions 2018-Feb-01 16:08 UTC 2018-May-02 16:08 UTC 89 days bigbadwolf.productions
318479785 bigbadwolf.productions 2018-Feb-01 15:58 UTC 2018-May-02 15:58 UTC 89 days bigbadwolf.productions
www.bigbadwolf.productions
318478019 bigbadwolf.productions 2018-Feb-01 15:55 UTC 2018-May-02 15:55 UTC 89 days bigbadwolf.productions
318477523 bigbadwolf.productions 2018-Feb-01 15:54 UTC 2018-May-02 15:54 UTC 89 days bigbadwolf.productions
318445797 bigbadwolf.productions 2018-Feb-01 14:57 UTC 2018-May-02 14:57 UTC 89 days bigbadwolf.productions
318444930 bigbadwolf.productions 2018-Feb-01 14:54 UTC 2018-May-02 14:54 UTC 89 days bigbadwolf.productions
And you have issued 5 certificates covering the same two domains bigbadwolf.productions & www.bigbadwolf.productions so you have reached the limit of 5 duplicate certificates per 7 days, so I think the error you are seeing is because you hit this limit.
I can not remember having created so many.
So should I wait 7 days before I try again or can I use one of the certificates?
Sorry i am an absolute beginner what ssl is concerned.
You have issued several certificates but I can't be sure they are saved in your server. I don't use Plesk so I know nothing about how it works or manages the conf and issued certs so I think the best you can do is explain the problem to your hosting provider and they should be able to check and solve the issue or guide you to use the right process for your environment.
