My domain is: xsxtc.ddns.net
I ran this command: N/A
It produced this output: N/A
My web server is (include version): None
The operating system my web server runs on is (include version): None
My hosting provider, if applicable, is: None
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): N/A
I am not experienced in these matters. I run a Lets Encrypt certificate on my domain hosted on a VPS and it works fine.
I want to run Let’s Encrypt on my dynamic domain xsxtc.ddns.net which points at my home (ISP) router with a dynamic WAN and 192.168.1.0/24 LAN. The noip.com client (that maintains verification of the dynamic IP) is integrated into my ISP router and it works.
I then pass all traffic (except VOIP telephones) to a second openwrt router behind the ISP router which runs my dhcp service for all connections On 10.0.0.0/24 LAN. So there is no main web server as such.
The ISP Router forwards external ports to my openwrt router. My router forwards that port to internal machine ports. So for example xsxtc.ddns.net:12345 forwards to 12345 which then forwards to 8123 internally to access my home assistant server.
When I access any of my internal servers (such as home assistant) I get a Not Secure message as no certificate exists for xsxtc.ddns.net. To access the internal machine I have to go through the certificate acceptance process each time.
So how and where do I apply a security certificate to overcome this security barrier? I assume it should go on my first ISP Router but how? I do not own or control ddns.net of which xsxtc is a subdomain. Is there a solution?
Geoff
