My domain is: pretalx.charmedhypno.org
I ran this command: certbot --nginx
root@instance-1:/etc/nginx/sites-available# certbot --nginx
blank to select all options shown (Enter ‘c’ to cancel):
http-01 challenge for pretalx.charmedhypno.org
Waiting for verification…
Failed authorization procedure. pretalx.charmedhypno.org (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://pretalx.charmedhypno.org/.well-known/acme-challenge/P3d9SUdRUPxS_8utzgMzct3qgRL0nbB9b7FBqQjzEZA: Timeout during connect (likely firewall problem)
Domain: pretalx.charmedhypno.org
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
NGINX v1.14.0 (Ubuntu)
Ubuntu 18.04
This is a VM instance running on Google Cloud
Yes
No
or certbot-auto --version
if you’re using Certbot): 0.31.0
The certificate has been working for 6 months, meaning one successful renewal, but it didn’t auto-renew this time and it expired today. It reads like it can’t get to port 80, but port 80 is open (and redirected) just as it has always been. Nobody futzes with this server – I had to look up my login credentials it’s been so long. What gives?
