Certificate expired and renewed it using command and updated ssl.conf but its not working now
This post was flagged by the community and is temporarily hidden.
You used “certonly”, which won’t install the certificate for you. You need to install the certificate then restart apache.
You’ve got plenty of valid certificates per https://crt.sh/?q=demos.kobil.com :
This is currently the problem:
That’s your time @freessltools.com :wink: Or at least, the error message is about your time and doesn’t reflect the actual issue at all unfortunately…
But my time is correct everywhere else. I believe that error is caused when my clock doesn’t fall within the valid date range of the certificate.
Hi @viral
don’t worry about your clock.
There is a check of your domain, 18.08.2020 14:24:46 - https://check-your-website.server-daten.de/?q=demos.kobil.com
With correct headers:
Date: Tue, 18 Aug 2020 12:25:48 GMT
Server: Apache/2.4.37 (centos) OpenSSL/1.1.1c
So it’s not a date/time problem of your server.
PS: Checking the other parts of your check - https://check-your-website.server-daten.de/?q=demos.kobil.com#ct-logs
The long version of the CT-Log - part shows: You have created two certificates this morning:
Last:
2020-08-18 10:14:48
May be the time is wrong (not GMT).
Thank You SSL configured now.
Thank you SSL configured now.
