Certicate is not valid
www.scineuromodulation.com
/snap/bin/certbot renew --allow-subset-of-names
Processing /etc/letsencrypt/renewal/scineuromodulation.com.conf
Ubuntu 20.04 nginx
nginx/1.18.0 (Ubuntu)
google cloud
No
certbot 2.7.0
www and base domain is different thing, get a new certificate with both www version and without www
There is both www and bare domain in the config. That site has been using cerbot for several years, with no issues. Until now. I got an email from 'Let's Encrypt Expiry Bot' . The cert was renewed on Sept 20.
when I connect https://www.sci~~~~.com servers certificate it just for scineuromodulation.com, and doesn't cover www.scineuromodulation.com your last cerficiate from 2023/8/1 did cover both but newest certificate on 2023/9/30 doesn't
How to fix?
" /etc/letsencrypt/live/scineuromodulation.com/fullchain.pem expires on 2023-12-29 (skipped)"
create a new certificate
certbot --nginx -d name1 -d name2
I get this when I run that:
(U)pdate key type/(K)eep existing key type:
I don't what it wants?
An RSA certificate named scineuromodulation.com already exists. Do you want to
update its key type to ECDSA?
If answer yes, it just keeps saying the same thing:
(U)pdate key type/(K)eep existing key type: ECDSA
(U)pdate key type/(K)eep existing key type: yes
(U)pdate key type/(K)eep existing key type: YES
not much matter, toss a coin or keep it
how so? What is the right answer? I don't care about ECDSA.
Please show the output of the command:
sudo certbot certificates
Sounds like you have multiple certificates and your webserver is using the incorrect one.
Found the following certs:
Certificate Name: assentushealth.com
Serial Number: 4880b622e5a6d483c7ce8f4d7e3b816a563
Key Type: RSA
Domains: assentushealth.com www.assentushealth.com
Expiry Date: 2023-12-02 06:11:44+00:00 (VALID: 52 days)
Certificate Path: /etc/letsencrypt/live/assentushealth.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/assentushealth.com/privkey.pem
Certificate Name: lakejericho.com
Serial Number: 4b4eecaa3b6fabeadb48e5509c60f043bdd
Key Type: RSA
Domains: lakejericho.com www.lakejericho.com
Expiry Date: 2023-12-10 05:06:15+00:00 (VALID: 60 days)
Certificate Path: /etc/letsencrypt/live/lakejericho.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/lakejericho.com/privkey.pem
Certificate Name: lorialdrycleaners.com
Serial Number: 4af887c26f95d078397f9081e1140236f82
Key Type: RSA
Domains: www.lorialdrycleaners.com
Expiry Date: 2023-11-23 10:38:05+00:00 (VALID: 43 days)
Certificate Path: /etc/letsencrypt/live/lorialdrycleaners.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/lorialdrycleaners.com/privkey.pem
Certificate Name: recoverytapers.org
Serial Number: 352ab47b1144d9dd53ecddba0a95c902443
Key Type: RSA
Domains: recoverytapers.org www.recoverytapers.org
Expiry Date: 2023-12-16 05:01:47+00:00 (VALID: 66 days)
Certificate Path: /etc/letsencrypt/live/recoverytapers.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/recoverytapers.org/privkey.pem
Certificate Name: scineuromodulation.com
Serial Number: 332f07cad539194ec943842671d3d370437
Key Type: RSA
Domains: scineuromodulation.com
Expiry Date: 2023-12-29 05:04:13+00:00 (VALID: 79 days)
Certificate Path: /etc/letsencrypt/live/scineuromodulation.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/scineuromodulation.com/privkey.pem
So it looks like you don't have a certificate valid for scineuromodulation.com currently any longer. You used to have that tho, see crt.sh | scineuromodulation.com. For some reason the www part got removed. Using --allow-subset-of-names might have caused that.
I agree with @orangepizza that getting a new certificate with both hostnames is the way to go now. Answering "yes" or "no" to a "do you want oranges or apples?" is not the correct answer by the way. Certbot was asking you to update, by answering with a "U" or to keep the current key type by answering with a "K". Not yes/no.
That did it! Thx!
https://www.scineuromodulation.com/
In this case, I think @Osiris was saying that you might have created this discrepancy by using --allow-subset-of-names in the past, and not suggesting that you use it now in order to fix the discrepancy.
