Certbox on Ubunutu 16.04 Not Installing - apt-get and disk space issues
Hi.
I originally installed a certbox certificate 6 months ago. Inbetween the server was updated, but the certbot command started to fail
I tied uninstalling and reinstalling using the instructions, but now I get the following when I tried to install certbox
You might want to run ‘apt-get -f install’ to correct these:
The following packages have unmet dependencies:
certbot : Depends: python-certbot (= 0.11.1-1+certbot~xenial+3) but it is not going to be installed
linux-headers-generic : Depends: linux-headers-4.4.0-71-generic but it is not going to be installed
linux-image-virtual : Depends: linux-image-4.4.0-71-generic but it is not going to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
I’ve done the apt-get -f and it made no difference
any ideas
Marc Nealer
FIgured it out. Not so obvious, but apt was complaining about disk space. Had to delete old Linux kernel files and then the install went fine
