Certbot won't authenticate my subdomain
My domain is: api.trendstudentstorage.com
I ran this command: sudo certbot --nginx -d api.trendstudentstorage.com --expand
Requesting a certificate for api.trendstudentstorage.com
Domain: api.trendstudentstorage.com
Detail: 3.33.152.147: Invalid response from http://api.trendstudentstorage.com/.well-known/acme-challenge/ELkRRLHyFkl3hpiI1QSExF9lWJTb7nDuVQUk9l94ekE: 404
My web server is (include version): Nginx
The operating system my web server runs on is (include version): Ubuntu
My hosting provider, if applicable, is: Digital Ocean
Welcome @Marois2000
It looks like you are still changing your DNS setup. You were using some sort of URL or Domain forwarding service but now don't have any A record for your IP.
Let us know when you finish your setup
