Certbot validation randomly succeeded or failed
Hello, I'm trying to create a certificate for a domain, but the process randomly succeeds or fails. I used the tool https://letsdebug.net, and the results varied: sometimes errors, sometimes fatal errors, and somtimes succeeded.
My domain is: user-mgmt.digital.auto
I ran this command: sudo certbot --nginx -d user-mgmt.digital.auto -d user-mgmt.digitalauto.tech
requested (ref: /etc/letsencrypt/renewal/user-mgmt.digitalauto.tech.conf)
It contains these names: user-mgmt.digitalauto.tech
You requested these names for the new certificate: user-mgmt.digital.auto,
certificate?
(E)xpand/(C)ancel: e
Renewing an existing certificate for user-mgmt.digital.auto and user-mgmt.digitalauto.tech
Domain: user-mgmt.digital.auto
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for user-mgmt.digital.auto - check that a DNS record exists for this domain; no valid AAAA records found for user-mgmt.digital.auto
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): ubuntu 23.04
My hosting provider, if applicable, is: Azure
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): name.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
Your DNS is quite the mess:
https://dnsviz.net/d/user-mgmt.digital.auto/dnssec/
It looks like 2 different companies are used as authorative nameservers. The name.com NS actually report an IP address indeed, but apparently wixdns.net NS are also being used currently, reporting an NXDOMAIN result.
See also the trace at Dig web interface - online dns lookup tool.
