Certbot Upgrade Not Working
Hi! I have the same issue, please help.
I am running Ubuntu 17.10 on a Digital Ocean droplet and have been trying to upgrade certbot from 0.22.2-1+ubuntu17.10.1+certbot+1 in order to deal with the TLS-SNI-01 validation end of life issue.
I have run every command I can find to update and upgrade certbot, and as near as I can tell they have all run successfully. Despite these efforts, however, every time I run certbot --version, the return says I’m still using certbot 0.22.2
All help is greatly appreciated!
Hey @quack ! Your issue stems from the fact that Ubuntu 17.10 reached its end of life on 19th of July 2018. No updates (including security updates) have been provided for your version since. You are strongly urged to upgrade!
If you wish to run a version of Ubuntu for longer time before the need to upgrade to a newer major version, I suggest you upgrade to an LTS (Long Term Support) version. The differences in the time a specific version is supported can be seen at https://en.wikipedia.org/wiki/Ubuntu_version_history#Version_timeline to give you a clear picture about the differences.
Thank you, it makes sense.
I am also having trouble upgrading certbot on Ubuntu 18.04. I have tried both apt and apt-get, but no luck. But I see that the current version of certbot for Ubuntu 18.04 is 0.23, which is far behind the current version:
https://packages.ubuntu.com/bionic/certbot
Am I missing something here?
Have you enabled the Certbot PPA and run “sudo apt update”? The PPA has version 0.28.0. Ubuntu’s own repositories only have 0.23.0, as you saw.
Got it, I somehow missed that when setting up. Works now, thanks!
Got --dry-run tested OK?
Yup, dry run passes with no problems.
When I run sudo apt-get update, I get connection failed errors to the PPA server. Thus, when I try to upgrade, apt still tells me that I’m on the latest version, which it thinks is 0.26.
On 14.04 LTS:
Ign http://us.archive.ubuntu.com trusty InRelease
Hit http://us.archive.ubuntu.com trusty-updates InRelease
Hit http://us.archive.ubuntu.com trusty-backports InRelease
Hit http://us.archive.ubuntu.com trusty Release.gpg
Hit http://security.ubuntu.com trusty-security InRelease
Ign http://ppa.launchpad.net trusty InRelease
Hit http://us.archive.ubuntu.com trusty-updates/main Sources
Hit http://us.archive.ubuntu.com trusty-updates/restricted Sources
Hit http://us.archive.ubuntu.com trusty-updates/universe Sources
Hit http://us.archive.ubuntu.com trusty-updates/multiverse Sources
Hit http://us.archive.ubuntu.com trusty-updates/main amd64 Packages
Hit http://us.archive.ubuntu.com trusty-updates/restricted amd64 Packages
Hit http://security.ubuntu.com trusty-security/main Sources
Hit http://us.archive.ubuntu.com trusty-updates/universe amd64 Packages
Err http://ppa.launchpad.net trusty Release.gpg
  Connection failed
Hit http://us.archive.ubuntu.com trusty-updates/multiverse amd64 Packages
Hit http://us.archive.ubuntu.com trusty-updates/main i386 Packages
Hit http://security.ubuntu.com trusty-security/restricted Sources
Hit http://us.archive.ubuntu.com trusty-updates/restricted i386 Packages
Hit http://us.archive.ubuntu.com trusty-updates/universe i386 Packages
Hit http://us.archive.ubuntu.com trusty-updates/multiverse i386 Packages
Hit http://us.archive.ubuntu.com trusty-updates/main Translation-en
Hit http://security.ubuntu.com trusty-security/universe Sources
Hit http://us.archive.ubuntu.com trusty-updates/multiverse Translation-en
Ign http://ppa.launchpad.net trusty Release
Hit http://us.archive.ubuntu.com trusty-updates/restricted Translation-en
Hit http://us.archive.ubuntu.com trusty-updates/universe Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse Sources
Hit http://us.archive.ubuntu.com trusty-backports/main Sources
Hit http://us.archive.ubuntu.com trusty-backports/restricted Sources
Hit http://us.archive.ubuntu.com trusty-backports/universe Sources
Hit http://us.archive.ubuntu.com trusty-backports/multiverse Sources
Hit http://security.ubuntu.com trusty-security/main amd64 Packages
Hit http://us.archive.ubuntu.com trusty-backports/main amd64 Packages
Ign http://ppa.launchpad.net trusty/main amd64 Packages/DiffIndex
Hit http://us.archive.ubuntu.com trusty-backports/restricted amd64 Packages
Hit http://us.archive.ubuntu.com trusty-backports/universe amd64 Packages
Hit http://security.ubuntu.com trusty-security/restricted amd64 Packages
Hit http://us.archive.ubuntu.com trusty-backports/multiverse amd64 Packages
Hit http://us.archive.ubuntu.com trusty-backports/main i386 Packages
Hit http://us.archive.ubuntu.com trusty-backports/restricted i386 Packages
Hit http://us.archive.ubuntu.com trusty-backports/universe i386 Packages
Hit http://security.ubuntu.com trusty-security/universe amd64 Packages
Hit http://us.archive.ubuntu.com trusty-backports/multiverse i386 Packages
Ign http://ppa.launchpad.net trusty/main i386 Packages/DiffIndex
Hit http://us.archive.ubuntu.com trusty-backports/main Translation-en
Hit http://us.archive.ubuntu.com trusty-backports/multiverse Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse amd64 Packages
Hit http://us.archive.ubuntu.com trusty-backports/restricted Translation-en
Hit http://security.ubuntu.com trusty-security/main i386 Packages
Hit http://us.archive.ubuntu.com trusty-backports/universe Translation-en
Hit http://us.archive.ubuntu.com trusty/main Sources
Hit http://us.archive.ubuntu.com trusty/restricted Sources
Hit http://us.archive.ubuntu.com trusty/universe Sources
Hit http://security.ubuntu.com trusty-security/restricted i386 Packages
Hit http://us.archive.ubuntu.com trusty/multiverse Sources
Hit http://us.archive.ubuntu.com trusty/main amd64 Packages
Hit http://us.archive.ubuntu.com trusty/restricted amd64 Packages
Hit http://security.ubuntu.com trusty-security/universe i386 Packages
Hit http://us.archive.ubuntu.com trusty/universe amd64 Packages
Hit http://us.archive.ubuntu.com trusty/multiverse amd64 Packages
Hit http://us.archive.ubuntu.com trusty/main i386 Packages
Hit http://us.archive.ubuntu.com trusty/restricted i386 Packages
Hit http://security.ubuntu.com trusty-security/multiverse i386 Packages
Hit http://us.archive.ubuntu.com trusty/universe i386 Packages
Hit http://us.archive.ubuntu.com trusty/multiverse i386 Packages
Hit http://us.archive.ubuntu.com trusty/main Translation-en
Hit http://security.ubuntu.com trusty-security/main Translation-en
Hit http://us.archive.ubuntu.com trusty/multiverse Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse Translation-en
Hit http://us.archive.ubuntu.com trusty/restricted Translation-en
Hit http://security.ubuntu.com trusty-security/restricted Translation-en
Hit http://us.archive.ubuntu.com trusty/universe Translation-en
Hit http://security.ubuntu.com trusty-security/universe Translation-en
Ign http://us.archive.ubuntu.com trusty/main Translation-en_US
Ign http://us.archive.ubuntu.com trusty/multiverse Translation-en_US
Ign http://us.archive.ubuntu.com trusty/restricted Translation-en_US
Ign http://us.archive.ubuntu.com trusty/universe Translation-en_US
Err http://ppa.launchpad.net trusty/main Translation-en_US
  Connection failed
  Connection failed
Err http://ppa.launchpad.net trusty/main amd64 Packages
  Connection failed
Err http://ppa.launchpad.net trusty/main i386 Packages
  Connection failed
W: Failed to fetch http://ppa.launchpad.net/certbot/certbot/ubuntu/dists/trusty/Release.gpg  Connection failed
W: Failed to fetch http://ppa.launchpad.net/certbot/certbot/ubuntu/dists/trusty/main/i18n/Translation-en_US  Connection failed
W: Failed to fetch http://ppa.launchpad.net/certbot/certbot/ubuntu/dists/trusty/main/i18n/Translation-en  Connection failed
W: Failed to fetch http://ppa.launchpad.net/certbot/certbot/ubuntu/dists/trusty/main/binary-amd64/Packages  Connection failed
W: Failed to fetch http://ppa.launchpad.net/certbot/certbot/ubuntu/dists/trusty/main/binary-i386/Packages  Connection failed
E: Some index files failed to download. They have been ignored, or old ones used instead.
On 16.04 LTS:
Hit:3 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Get:4 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
Get:6 http://security.ubuntu.com/ubuntu xenial-security InRelease [109 kB]
Ign:7 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial InRelease
Get:8 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
Ign:9 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial Release
Hit:10 https://apt.dockerproject.org/repo ubuntu-xenial InRelease
Ign:11 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main amd64 Packages.diff/Index
Ign:12 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main i386 Packages.diff/Index
Ign:13 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main all Packages
Ign:14 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main Translation-en_US
Ign:15 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main Translation-en.diff/Index
Ign:16 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main amd64 Packages
Ign:17 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main i386 Packages
Ign:18 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main Translation-en
Err:16 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial/main amd64 Packages
  Connection failed
Fetched 329 kB in 6s (51.2 kB/s)
Reading package lists... Done
W: The repository 'http://ppa.launchpad.net/certbot/certbot/ubuntu xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://ppa.launchpad.net/certbot/certbot/ubuntu/dists/xenial/main/binary-amd64/Packages  Connection failed
W: Some index files failed to download. They have been ignored, or old ones used instead.
