Okay I'll look into that. Thanks so much for your help!
Please show what the reverse proxy is doing with the failed requests.
As of last night, I shut the Node server down before going to sleep, I'll turn it back on when I start testing again. I have some other priorities that I have to focus on until later tonight.
The Node server does run successfully though, and there are no failed requests when it is running. That's the weird part. I am able to run a Node server on port 80 and it works fine, but the Certbot doesn't.
@ThomasWithYondo I see you got a fresh cert 4 days ago.
Did you find a definitive solution? I'm just curious as the symptoms were so odd. Thx
