CertBot unable to install certificate on fresh apache2 installation
nope i'm just bad at pasting
$ sudo ls -la /etc/apache2/sites-available
total 16
drwxr-xr-x 2 root root 4096 Apr  4 06:08 .
drwxr-xr-x 8 root root 4096 Apr  4 02:50 ..
-rw-r--r-- 1 root root 1089 Apr  4 02:50 2darkpark.net-le-ssl.conf
-rw-r--r-- 1 root root  483 Apr  4 06:08 2darkpark.net.conf
Let's try this:
sudo a2dissite 2darkpark.net.conf
sudo a2ensite 2darkpark.net.conf
sudo apachectl -k restart
sudo cat /etc/apache2/sites-enabled/2darkpark.net.conf
$ sudo a2dissite 2darkpark.net.conf
Site 2darkpark.net disabled.
To activate the new configuration, you need to run:
  systemctl reload apache2
$ sudo a2ensite 2darkpark.net.conf
Enabling site 2darkpark.net.
$ sudo apachectl -k restart
'AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
$ sudo cat /etc/apache2/sites-enabled/2darkpark.net.conf
<VirtualHost *:80>
	ServerName 2darkpark.net
	ServerAlias www.2darkpark.net
	ServerAdmin nat@2darkpark.net
	DocumentRoot /var/www/html
	Redirect permanent "/" "https://www.2darkpark.net/"
	#RewriteEngine on
	#RewriteCond %{SERVER_NAME} =www.2darkpark.net [OR]
	#RewriteCond %{SERVER_NAME} =2darkpark.net
	#RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
Are you actually using tab characters in your conf file?
Er, yes, is that a problem?
Replace them all with spaces if you would. Please put 4 spaces at the beginning of each line in the conf file (except for the blank lines, which should have no characters at all).
Show me this again once you're done:
edit:
put no spaces before the virtualhost lines
Erk, didn't know that tabs were an issue. If it wasn't already obvious, I have much to learn.
<VirtualHost *:80>
    DocumentRoot /var/www/html/
    #RewriteEngine on
</VirtualHost>
One moment... checking something...
And again now...
Still defaults http! This is getting somewhat absurd.
hmm... one moment... :thinking:
Are you using a Digital Ocean load balancer?
Er, no idea. if it's on by default, then probably yes. I'm only paying for one CPU core though, so I would think it's not enabled?
I wonder...
sudo apachectl -S
sudo cat /etc/apache2/sites-enabled/2darkpark.net-le-ssl.conf
$ sudo apachectl -S
VirtualHost configuration:
*:443                  www.2darkpark.net (/etc/apache2/sites-enabled/2darkpark.net-le-ssl.conf:2)
*:80                   is a NameVirtualHost
         default server 2darkpark.net (/etc/apache2/sites-enabled/2darkpark.net-le-ssl.conf:17)
         port 80 namevhost 2darkpark.net (/etc/apache2/sites-enabled/2darkpark.net-le-ssl.conf:17)
                 alias www.2darkpark.net
         port 80 namevhost 2darkpark.net (/etc/apache2/sites-enabled/2darkpark.net.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
$ sudo cat /etc/apache2/sites-enabled/2darkpark.net-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
    ServerName www.2darkpark.net
ServerAlias 2darkpark.net
SSLCertificateFile /etc/letsencrypt/live/www.2darkpark.net/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.2darkpark.net/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =www.2darkpark.net [OR]
# RewriteCond %{SERVER_NAME} =2darkpark.net
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
</IfModule>
and there it is.. :grin:
:laughing:
Edit /etc/apache2/sites-available/2darkpark.net-le-ssl.conf
Remove everything from the second copy of the following line to the end of the file (including this line):
Then run these:
sudo apachectl -S
edit:
In essence you're removing the second virtualhost and the surrounding "if" lines.
Oh my lord I should have been able to figure that one out myself
Thank you so much for your help!
Redirects are working now!
:grin: :partying_face:
hang on, what the hell? navigating to 2darkpark.net defaults to https, but www.2darkpark.net does not.
