Ok... I upgraded python3, nuked and reinstalled a bunch of libraries, and now certbot is working. Rewinding to where we were earlier, I was able to do certbot certificates:
~$ sudo /root/bin/certbot-auto renew --no-self-upgrade --no-bootstrap
Your system is not supported by certbot-auto anymore.
Certbot will no longer receive updates.
Please visit https://certbot.eff.org/ to check for other alternatives.
Processing /etc/letsencrypt/renewal/xyzzy.org.conf
Attempting to parse the version 0.31.0 renewal configuration file found at /etc/letsencrypt/renewal/xyzzy.org.conf with version 0.21.1 of Certbot. This might not work.
Attempting to renew cert (xyzzy.org) from /etc/letsencrypt/renewal/xyzzy.org.conf produced an unexpected error: 'Directory field not found': new_authz. Skipping.
/etc/letsencrypt/live/xyzzy.org/fullchain.pem (failure)
The main advantage of certbot for me is that I have a guy who understands this better than I do who maintains a similar machine, and I can copy what he does there (and, until today, it worked fine.)
But I've installed acme.sh; it has added the following cron job:
34 0 * * * "/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null
Is that all I need to do to replace the cron job running sh /root/bin/certbot_update.sh ?
That was today, in response to the email telling me my certs were going to expire. Before that, I touched nothing. I (usually) know when to leave well enough alone!
So does acme.sh serve the same function as certbot_update, and will the default acme cron job (which I showed above) keep my certs updated?
I don't know what certbot_update is...
But I would have to say NO. certbot and acme.sh do the same things - they are two ACME clients.
Right now acme.sh will run and do nothing as is has no certs that it maintains.
certbot should also run and will maintain its' certs when that time comes.
Your subsequent posting suggests that I need to get new certs with acme, and that acme and certbot manage different certificates. So, if I'm clear, that means that by moving to acme, I need to apply for new certificates and abandon the ones I currently have with certbot.
Sorry if I sound dense; I started off with what I thought would be a simple question, and it has become a much bigger issue than I imagined it could have, as these things sometimes do.
You get the picture just fine.
They store cert files differently and in different locations.
So, yes, you would have to redo any certbot certs that you want to move over to acme.sh.
But it's a very simple process.
You can do them one at a time.
But to clearly answer your question: NO.
They do similar things to different softwares.
To be clear: ACME.SH and CERTBOT are like...
COKE and PEPSI
BURGER KING and McDONALDS
FORD and CHEVY
[Except they are not in the for profit business, so they don't fight for users!]
They do very similar things - but in their own completely separate ways.
Probably, if acme.sh installed the cronjob/systemd timer correctly. However, I don't have much experience with acme.sh so YMMV. Check to be certain in 60 days of course. Set it in your calendar
By the way: mixing up certbot and certbot-auto is recipe for disaster. Although you've switched to a different ACME client now, I find it important for you to know the difference between all kinds of possible ACME clients and/or methods of installation out there. The difference can be big.
Acme.sh is a great client. Small, but verstatile. However, not everything is that well documented and there isn't that much experience with it on this Community. Certbot should be a little bit more userfriendly and there is much experience with it here.
