Certbot SSL Renewal - same expiration date
The config file doesn't have fullchain4.pem in the file. You are asking for the fullchain4.pem. Does that matter?
Edit the file:
vi /etc/letsencrypt/archive/mail.allanimals.info/chain4.pem
OR
nano /etc/letsencrypt/archive/mail.allanimals.info/chain4.pem
And replace the contents with the last two certs you just posted.
I repeat myself:
But to answer your question:
The chain4.pem is the broken file.
It is referenced by the common name in the /live/ folder (as "chain.pem").
[if you open that renewal.conf file you will see]
File modified as requested. I am asking additional questions so I understand the concept and process.
You can go back and review all the steps - they will be here.
Now we need to rerun:
certbot certificates
And see if that clears half the problem.
If so, then redo the same thing for the -0001 folder fullhain1.pem/chain1.pem files.
Renewal configuration file /etc/letsencrypt/renewal/mail.allanimals.info-0001.conf produced an unexpected error: fullchain does not match cert + chain for mail.allanimals.info-0001!. Skipping.
Found the following certs:
Certificate Name: mail.allanimals.info
Serial Number: 4a2c7776491b90169172143c6bd095db22e
Key Type: RSA
Domains: mail.allanimals.info
Expiry Date: 2023-01-27 17:03:16+00:00 (VALID: 1 day)
Certificate Path: /etc/letsencrypt/live/mail.allanimals.info/fullchain.pem
Private Key Path: /etc/letsencrypt/live/mail.allanimals.info/privkey.pem
The following renewal configurations were invalid:
That actually fixed that part of the problem.
This other part seems a bit different.
Getting the file info...
Wait!
This one looks right:
We need to look into the renewal conf files!!!!!!!
cat /etc/letsencrypt/renewal/mail.allanimals.info.conf
cat /etc/letsencrypt/renewal/mail.allanimals.info-0001.conf
[reordered post for later reading chronologically]
renew_before_expiry = 30 days
version = 1.32.2
archive_dir = /etc/letsencrypt/archive/mail.allanimals.info
cert = /etc/letsencrypt/live/mail.allanimals.info/cert.pem
privkey = /etc/letsencrypt/live/mail.allanimals.info/privkey.pem
chain = /etc/letsencrypt/live/mail.allanimals.info/chain.pem
fullchain = /etc/letsencrypt/live/mail.allanimals.info/fullchain.pem
[renewalparams]
account = 994651a718b257d6f21dd3959b6cc9d6
authenticator = standalone
key_type = rsa
preferred_chain = ISRG Root X1
version = 1.31.0
archive_dir = /etc/letsencrypt/archive/mail.allanimals.info-0001
cert = /etc/letsencrypt/live/mail.allanimals.info-0001/cert.pem
privkey = /etc/letsencrypt/live/mail.allanimals.info-0001/privkey.pem
chain = /etc/letsencrypt/live/mail.allanimals.info-0001/chain.pem
fullchain = /etc/letsencrypt/live/mail.allanimals.info-0001/fullchain.pem
[renewalparams]
key_type = rsa
root@mail:/etc/letsencrypt/live/mail.allanimals.info-0001#
Man, both look right.
Let's go with the same edit that worked on the other folder.
Sorry, I missed that post altogether.
It will never show any number there.
The number is only updated in the symlink - which NEVER changes.
You will always find the latest file (number) at the /live/ folder [without numbers].
To clarify:
Take these:
and put them both into:
/etc/letsencrypt/renewal/mail.allanimals.info-0001/fullchain.pem
Is that correct?
cat /etc/letsencrypt/archive/mail.allanimals.info-0001/fullchain1.pem
Edit the file:
vi /etc/letsencrypt/archive/mail.allanimals.info-0001/chain1.pem
OR
nano /etc/letsencrypt/archive/mail.allanimals.info-0001/chain1.pem
And replace the contents with the last two certs from the fullchain1.pem file.
Not sure... let me check which it the broken file???
[chain OR fullchain]
Impossible to tell from the timestamps which one is off.
We need to see all three [NOT the PRIVKEY file - never post those].
cat /etc/letsencrypt/archive/mail.allanimals.info-0001/cert1.pem
cat /etc/letsencrypt/archive/mail.allanimals.info-0001/chain1.pem
The sizes are off:
1858+3765 is way bigger than 3684 [which is smaller than the chain1.pem]
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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MIIFazCCA1OgAwIBAgIRAIIQz7DSQONZRGPgu2OCiwAwDQYJKoZIhvcNAQELBQAw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=
nLRbwHOoq7hHwg==
wow certbot really need --reset-hard option
OK the cert looks fine.
The chain has two entries.
The fullchain has the cert but only one entry.
Go ahead and add the last cert from the chain to the fullchain [at the end].
That should set things right.
Yeah, this was way beyond update_symlinks LOL
