Certbot - Setting Up HTTPS for PHPADMIN on Apache
Hello,
I tried to get the certificate with this command /root/certbot-auto --apache
but it failed and this is the error msg
tls-sni-01 challenge for www.projecttoe.com
Waiting for verification…
Failed authorization procedure. www.projecttoe.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 192.237.246.35:443 for tls-sni-01 challenge
the server is Apache on centos .
I stopped the web server and run certbot in standalone mode , i got the certificate and config vhost to support ssl but when Apache comes up https doesn’t work.
any help??
Thanks
@dalia
Are you sure. https://crt.sh/?q=%projecttoe.com seems to disagree
Andrei
you are right, i got the cer for phpmyadmin interface http://prod.db.ptoenetwork.com. and it didn’t work also
https://crt.sh/?q=%prod.db.ptoenetwork.com
Hi @dalia
You will need to add a HTTPS server block to your Apache Config for PHPADMIN.
Currently you do not have a HTTPS binding on your site
https://www.tecmint.com/setup-https-ssl-certificates-to-secure-phpmyadmin-login/
Andrei
Hi Andrei,
solved, Thank you for ur help :slight_smile:
