Certbot says "No renewals were attempted"
Yes, use fullchain.pem as the name of the file and privkey.pem is the private key file.
What program caused the error message you posted? It should know these files not just the directory (usually). Was that from nginx? Show the config that caused the below error
1#1: cannot load certificate "/etc/letsencrypt/live/paleozoic.cloud": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
File begins with:
cat /etc/letsencrypt/live/paleozoic.cloud/fullchain.pem
[sudo: authenticate] Password:
-----BEGIN CERTIFICATE-----
MIIDoTCCAy...
Does it need to start with the phrase: "TRUSTED CERTIFICATE"?
or do you think nginx can't find the file?
Note the error message only describes the directory. It should name the fullchain.pem file.
The file is fine. The program that is trying to load it is not configured to use it.
At least, that's what it looks like to me. What program issued that error? Show its config
Of course, a bit stupid of me. Thanks to you both for pointing that out. I'd forgotten to straighten out my nginx-default.conf.
I'm up and running. Thank you for your patience with my lack of unix wizarding skills -- its been 40 years.
