My domain is: test.gosaenz.com
I ran this command: sudo /usr/local/bin/certbot certonly --webroot --agree-tos -w /etc/nginx/managed-ssl/letsencrypt -d test.gosaenz.com
It produced this output: Your system is not supported by certbot-auto anymore.
certbot-auto and its Certbot installation will no longer receive updates.
You will not receive any bug fixes including those fixing server compatibility
or security problems.
Please visit https://certbot.eff.org/ to check for other alternatives.
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/test.gosaenz.com.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the cert (may be subject to CA rate limits)
Renewing an existing certificate for test.gosaenz.com
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/test.gosaenz.com/fullchain.pem
/etc/letsencrypt/live/test.gosaenz.com/privkey.pem
Your cert will expire on 2021-12-15. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
"certbot renew" -
Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
My web server is (include version): nginx/1.19.2
The operating system my web server runs on is (include version): Amazon Linux 1
My hosting provider, if applicable, is: AWS
or certbot-auto --version
if you're using Certbot): certbot 1.10.1
Issue: Recently our certbot certificate registrations have been running really, really slow. It just started happening within the last 5 days and was performing fine just prior. It gets to the line in the output: "Renewing an existing certificate for test.gosaenz.com" and it will take 2-3 hours to complete. It does eventually complete but again after a few hours. I know we need certbot and OS upgrades but surprised how it just began to crawl speed-wise so quickly. Any help is appreciated.
