Certbot renew not working?
Could Augeas have some kind of memory leak due to some kind of weird Apache configuration fluke/weird syntax/whatever? And how would one prove or disprove such a thing? :thinking:
The problem is, this website is running off a .jar file and not the typical website that has all the files in /var/www/html... So not sure what I would put for the -w path..
Apache isn't running when I run certbot (otherwise certbot can't grab port 80). But in my httpd.conf, I have this:
Require all granted Include /etc/httpd/ipblacklist.conf
which uses the ipblacklist.conf file which has over 10K lines, each one reading:
Require ip not XX.XXX.XXX.XXX
Would that make certbot use extra memory?
Ha! That was it. I commented out ipblacklist.conf and it renewed!
Thank you for your time!
FYI this is only an issue when using the --standalone authenticator.
The --apache plugin is designed to allow Certbot to renew your certificates without stopping Apache. It doesn't need 80 free. When you stop Apache, Certbot starts it anyway.
Thanks. So does that mean I can just do: certbot renew, next time without stopping Apache first?
Personally, I would put such IP blocklists into my firewall, not Apache :slight_smile:
Yes, that is correct.
