Certbot renew gives incomprehensible errors
My domain is: alf4all.nl
I ran this command: sudo certbot renew
It produced this output: ?
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.8.0
After sudo certbot renew a lot of errors. After I opened port 80 i could renew my certificate. Now sudo certbot -v comes with:
Deploying certificate
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/alf4all.conf
Successfully deployed certificate for alf4all.nl to /etc/apache2/sites-enabled/alf4all.conf
Failed redirect for alf4all.nl
Unable to set the redirect enhancement for alf4all.nl.
NEXT STEPS:
  • The certificate was saved, but could not be installed (installer: apache). After fixing the error shown below, try installing it again by running:
    certbot install --cert-name alf4all.nl
Unable to find corresponding HTTP vhost; Unable to create one as intended addresses conflict; Current configuration does not support automated redirection
Other details of apache:
I made a symbolic link in /etc/apache2/sites-enabled -> alf4all.conf
certbot --install put at the end of alf4all.conf:
ServerName alf4all.nl
SSLCertificateFile /etc/letsencrypt/live/alf4all.nl/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/alf4all.nl/privkey.pem
on top of alf4all.conf:
ServerAdmin w.nijs@alf4all.demon.nl
0pptions-ssl-apache.conf:
SSLEngine on
SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLCipherSuite ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA>
SSLHonorCipherOrder off
SSLSessionTickets off
SSLOptions +StrictRequire
LogFormat "%h %l %u %t "%r" %>s %b "%{Referer}i" "%{User-agent}i"" vhost>
LogFormat "%v %h %l %u %t "%r" %>s %b" vhost_common
Pleas can somebody help or give a hint where to look? Thanks and regards...
Wijnand
Welcome back @Wijnand
Let us start by showing us the output of these two commands
ls -lR /etc/apache2/sites*
sudo apache2ctl -t -D DUMP_VHOSTS
What a service, thanks a lot...
ls -l /etc/apache2/sites* gives:
/etc/apache2/sites-available:
total 12
-rw-r--r-- 1 root root 1332 Mar 1 2023 000-default.conf
-rw-r--r-- 1 root root 6338 Mar 1 2023 default-ssl.conf
/etc/apache2/sites-enabled:
total 0
lrwxrwxrwx 1 root root 35 Jul 5 18:12 alf4all.conf -> /media/alf4all/apache2/alf4all.conf
wijnand@server-a:/etc/apache2$ ls -l /etc/apache2/sites*
total 12
total 0
wls -l /etc/apache2/sites* gives:
total 12
total 0
total 12
total 0
wijnand@server-a:/etc/apache2$ sudo apache2ctl -t -D DUMP_VHOSTS
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
88.159.57.235:443 alf4all.nl (/etc/apache2/sites-enabled/alf4all.conf:1)
88.159.57.235:80 alf4all.nl (/etc/apache2/sites-enabled/alf4all.conf:1)
I see the remark:
Is that the problem maybe?
I think the problem is probably because of your unusual sites-available / enabled usage. Normally you have the conf file in sites-available and link to it from sites-enabled. Then, your Apache includes all the files in sites-enabled.
But, let us look at your conf file too. Please show contents of below file and add 3 backticks before and after so we don't lose some of the Apache tags. Like this
contents of /etc/apache2/sites-enabled/alf4all.conf
First: with the link in sites-enabled to my alf4all.conf file has worked for years, second: after going to work with certification it worked perfect with https including the redirection from http to https. I got an email that I have to renew my certificates and from that time started the troubles... I try a lot and maybe I have do a lot of damage in the settings, that's the history... Now your question:
<VirtualHost alf4all.nl:80 alf4all.nl:443>
# VirtualHost alf4all
DocumentRoot "/media/alf4all/alf4all"
SetEnvIf Request_URI "\.(txt|jpg|png|gif|ico|js|css|swf|js?.|css?.)$" StaticContent
<Directory />
 Options FollowSymLinks
 AllowOverride None
</Directory>
<Directory "/media/alf4all/alf4all/">
 Options +Indexes +FollowSymLinks +MultiViews +Includes
 AllowOverride None
 Require all granted
 AddType text/html .htm
 AddOutputFilter INCLUDES .htm
</Directory>
# Alias roots
Alias /roots/ "/media/alf4all/roots/"
<Directory "/media/alf4all/roots/">
 AllowOverride None
 Require all granted
</Directory>
# Alias library
Alias /library/ "/media/alf4all/library/"
<Directory "/media/alf4all/library/">
 AllowOverride None
 Require all granted
</Directory>
# Alias archive
Alias /archive/ "/media/alf4all/archive/"
<Directory "/media/alf4all/archive/">
 AllowOverride None
 Require all granted
</Directory>
# Alias engineering
Alias /engineering/ "/media/alf4all/engineering/"
<Directory "/media/alf4all/engineering/">
 AllowOverride None
 Require all granted
</Directory>
# Alias povray
Alias /povray/ "/media/alf4all/povray/"
<Directory "/media/alf4all/povray/">
 AllowOverride None
 Require all granted
</Directory>
# Alias CGI script alias
ScriptAlias /cgi-bin/ /media/alf4all/cgi-bin/
<Directory "/media/alf4all/cgi-bin">
 Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
 AllowOverride None
 Require all granted
</Directory>
# Alias JavaScript alias
Alias /scripts/ "/media/alf4all/scripts/"
<Directory "/media/alf4all/scripts/">
 AllowOverride None
 Require all granted
</Directory>
# Access
Include /media/alf4all/apache2/access/access.conf
CustomLog /media/alf4all/apache2/logs/access.log combined env=!dontlog
SetEnvIf Remote_Addr "192.168.178.100" dontlog # local admin requests on server-a
SetEnvIf Remote_Addr "88.159.57.235"   dontlog # internet admin requests
# ErrorLog
ErrorLog /media/alf4all/apache2/logs/error.log
LogLevel warn
ErrorDocument 401 /custom_401.html
ErrorDocument 403 /custom_403.html
ErrorDocument 404 /custom_404.html
</VirtualHost>
If a call https://alf4all.nl/ with Firefox a got the message: SSL_ERROR_RX_RECORD_TOO_LONG what's the meaning of this error?
First, can you edit your post to use 3 backticks rather than 3 periods? On a US keyboard the backtick is in the upper left. Or, copy/paste the ones from my post.
You only have one symlink in /sites-enabled to alf4all.conf. But, that should have two VirtualHosts (one for port 80 and one for 443) but there is only one. Some of the apache tags were omitted by this forum's formatting because no backticks. So some items were lost but that cannot explain everything.
I can understand why Certbot would not know how to insert redirects from HTTP to HTTPS with such a config. Is this how it has always been?
Oke, I understand now the role of the 3 backticks. Still learning...
I remember the last thing I changed in the .conf was to replace <VirtualHost *:80> by because in some help on errors this would help to open 2 ports for the site.
And changed ownership and mode to www-data:www-data 775
Several issues here.
First, port 80 is currently blocked. You should check your router and firewall(s). Also, check that your ISP has not started blocking it. Some residential ISP's do this.
Second, you should not mix port 80 and port 443 in the same VirtualHost. You should create a new VirtualHost just for port 80 and change your existing VirtualHost statement to be <VirtualHost *:443>. Using a domain name in the VirtualHost makes it an IP-based VHost and name-based VHosts are easier to manage.
Now would be a good time to use the standard method of organizing conf files. That is, in /sites-available have one conf file for each VirtualHost and then use a2ensite and a2dissite to enable / disable them. It does this by making / removing a symlink in /sites-enabled to the /sites-available conf file.
Hello Mike (?), I solved the problem by
  1. Unblocking both ports 80 and and 443 on my router
  2. Changed the header of my alf4all.conf to:
<VirtualHost *:80>
  ServerAlias www.alf4all.nl
  Redirect permanent / https://alf4all.nl/
</VirtualHost>
<VirtualHost *:443>
  Protocols h2 http/1.1
  1. Keep my link to alf4all.conf in sites-enabled and no extra modifications or links in/to sites-enabled and/or sites-available.
So the big problems where that the server shares the two ports end the mix of two ports in the same VirtuslHost. Now it's working perfect
Thanks to help me with this problem, it was an eye opener, I have learned a lot (for an 73 years old man :wink:
Okay good. Much progress.
You have the name www.alf4all.nl as a ServerAlias which is fine. But, your cert does not have that name in it and there is no DNS A record for it either. No one will be able to use that domain name without these.
