I run a small webserver with a nextcloud instance.
Before I ran it behind my ISP router and all was well. I used the certbot script to renew the certificates.
Then I switched to Pfsense. All ran fine until the certificate ran out.
When I run the Certbot script I get a warning that I have an issue with my firewall.
Pfsense is set to default, the only thing I changed was the NAT to forward to my webserver on HTTPS and HTTP. (this is working fine).
I am using a no-ip dynamic updated domain. I don't have access to any DNS records.
I tried to generate the certificates on Pfsense itself but that seems to give the same issues.
Any tips on how to troubleshoot this?
Many thanks!
Karel.
My domain is:editoor.ddns.net
sudo certbot --apache
1: editoor.ddns.net
Renewing an existing certificate for editoor.ddns.net
http-01 challenge for editoor.ddns.net
Challenge failed for domain editoor.ddns.net
Domain: editoor.ddns.net
Type: connection
Detail: Fetching
http://editoor.ddns.net/.well-known/acme-challenge/H5u2Y9IINzRysZx1V5PGiXXxDOY99rfFUqdhUcOQT14:
My web server is (include version): Server version: Apache/2.4.6 (CentOS)
Server built: Nov 16 2020 16:18:20
The operating system my web server runs on is (include version): CentOS 7
My hosting provider, if applicable, is: no-ip.
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
or certbot-auto --version
if you're using Certbot): certbot 1.11.0
