Certbot Nginx Timeout w/ DDNS/NameCheap -- Port 80/443 Open
I spent quite a bit of time trying to figure out what’s causing this and am at a loss.
I have DDNS setup through namecheap -> tomato router -> computer.
I’m using their “A+ Dynamic DNS Record” and I also tried just a standard A Record.
Port 80 and 443 are definitely publicly accessible (not blocked by ISP or anything). example
Thanks for any help!
www.atomsandbits.ai
playground.atomsandbits.ai
sudo certbot --test-cert --nginx
2018/07/17 22:33:26 [notice] 13086#13086: signal process started
Failed authorization procedure. www.atomsandbits.ai (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.atomsandbits.ai/.well-known/acme-challenge/OzT1sDCNwUjDLePW-RHGRDV7_zxuY9p2K1li7XCQAko: Timeout during connect (likely firewall problem), playground.atomsandbits.ai (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://playground.atomsandbits.ai/.well-known/acme-challenge/BkeiBE6Qt6-OAqg1DhH5lwGyAx_MIUHyN6PydmQ5p40: Timeout during connect (likely firewall problem)
   Domain: www.atomsandbits.ai
   Type:   connection
   Detail: Fetching
   Domain: playground.atomsandbits.ai
   Type:   connection
   Detail: Fetching
nginx version: nginx/1.14.0
LSB Version: 1.4
Distributor ID: Arch
Description: Arch Linux
Release: rolling
Codename: n/a
namecheap
no
I can’t access them.
Is the IP address, 142.151.170.244, correct?
Have you double checked that the firewall and (if necessary) port forwarding are all correct?
Wow. I’m hosting from a dorm and didn’t realize that it just wasn’t accessible from outside of the school network (I tried on a few different school networks/locations).
Seems port 80 and 443 must be externally blocked for the whole campus. :frowning:
Thanks so much for the help!
