Certbot misconfiguration error: "duplicate extension "wasm"" and "no "ssl_certificate"" errors
My domain is: caviomorpha.dev
I ran this command: certbot --nginx -d matrix.caviomorpha.dev
Error while running nginx -c /etc/nginx/nginx.conf -t.
2024/03/17 16:50:54 [warn] 15616#15616: duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/sites-enabled/meet.caviomorpha.dev.conf:5
2024/03/17 16:50:54 [emerg] 15616#15616: no "ssl_certificate" is defined for the "listen ... ssl" directive in /etc/nginx/sites-enabled/matrix:1
nginx: configuration file /etc/nginx/nginx.conf test failed
The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError('Error while running nginx -c /etc/nginx/nginx.conf -t.\n\n2024/03/17 16:50:54 [warn] 15616#15616: duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/sites-enabled/meet.caviomorpha.dev.conf:5\n2024/03/17 16:50:54 [emerg] 15616#15616: no "ssl_certificate" is defined for the "listen ... ssl" directive in /etc/nginx/sites-enabled/matrix:1\nnginx: configuration file /etc/nginx/nginx.conf test failed\n')
My web server is (include version): nginx 1.22.1-9
The operating system my web server runs on is (include version): Debian 12
My hosting provider, if applicable, is: Vultr
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
Welcome @AKM4096
Can you post the contents of that file
The above is just a warning but points to something wrong with your config. I don't believe that interferes with Certbot but you should review and correct that.
server_names_hash_bucket_size 64;
types {
# nginx's default mime.types doesn't include a mapping for wasm or wav.
    application/wasm     wasm;
    audio/wav            wav;
upstream prosody {
    zone upstreams 64K;
    server 127.0.0.1:5280;
    keepalive 2;
upstream jvb1 {
    zone upstreams 64K;
    server 127.0.0.1:9090;
    keepalive 2;
map $arg_vnode $prosody_node {
    default prosody;
    v1 v1;
    v2 v2;
    v3 v3;
    v4 v4;
    v5 v5;
    v6 v6;
    v7 v7;
    v8 v8;
    listen 80;
    listen [::]:80;
    server_name meet.caviomorpha.dev;
    location ^~ /.well-known/acme-challenge/ {
        default_type "text/plain";
        root         /usr/share/jitsi-meet;
    location = /.well-known/acme-challenge/ {
        return 404;
    listen 443 ssl http2;
    listen [::]:443 ssl http2;
    # Mozilla Guideline v5.4, nginx 1.17.7, OpenSSL 1.1.1d, intermediate configuration
    ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:$
    ssl_prefer_server_ciphers off;
    ssl_session_timeout 1d;
    ssl_session_cache shared:SSL:10m;  # about 40000 sessions
    ssl_session_tickets off;
    add_header Strict-Transport-Security "max-age=63072000" always;
    set $prefix "";
    set $custom_index "";
    set $config_js_location /etc/jitsi/meet/meet.caviomorpha.dev-config.js;
    ssl_certificate /etc/jitsi/meet/meet.caviomorpha.dev.crt;
    ssl_certificate_key /etc/jitsi/meet/meet.caviomorpha.dev.key;
    # ssi on with javascript for multidomain variables in config.js
    ssi on;
    ssi_types application/x-javascript application/javascript;
    index index.html index.htm;
    error_page 404 /static/404.html;
    gzip on;
    gzip_types text/plain text/css application/javascript application/json image/x-icon application/octet-stream application/wasm;
    gzip_vary on;
    gzip_proxied no-cache no-store private expired auth;
    gzip_min_length 512;
    include /etc/jitsi/meet/jaas/*.conf;
    location = /config.js {
        alias $config_js_location;
    location = /external_api.js {
        alias /usr/share/jitsi-meet/libs/external_api.min.js;
    location = /_api/room-info {
        proxy_pass http://prosody/room-info?prefix=$prefix&$args;
        proxy_http_version 1.1;
        proxy_set_header X-Forwarded-For $remote_addr;
        proxy_set_header Host $http_host;
    location ~ ^/_api/public/(.*)$ {
        autoindex off;
        alias /etc/jitsi/meet/public/$1;
    # ensure all static content can always be found first
   location ~ ^/(libs|css|static|images|fonts|lang|sounds|.well-known)/(.*)$
        add_header 'Access-Control-Allow-Origin' '*';
        alias /usr/share/jitsi-meet/$1/$2;
        # cache all versioned files
        if ($arg_v) {
            expires 1y;
    # BOSH
    location = /http-bind {
        proxy_pass http://$prosody_node/http-bind?prefix=$prefix&$args;
        proxy_set_header Connection "";
    # xmpp websockets
    location = /xmpp-websocket {
        proxy_pass http://$prosody_node/xmpp-websocket?prefix=$prefix&$args;
        proxy_set_header Connection "upgrade";
        tcp_nodelay on;
    # colibri (JVB) websockets for jvb1
    location ~ ^/colibri-ws/default-id/(.*) {
        proxy_pass http://jvb1/colibri-ws/default-id/$1$is_args$args;
        tcp_nodelay on;
    # load test minimal client, uncomment when used
    #location ~ ^/_load-test/([^/?&:'"]+)$ {
    #    rewrite ^/_load-test/(.*)$ /load-test/index.html break;
    #location ~ ^/_load-test/libs/(.*)$ {
    #    add_header 'Access-Control-Allow-Origin' '*';
    #    alias /usr/share/jitsi-meet/load-test/libs/$1;
    location ~ ^/([^/?&:'"]+)$ {
        set $roomname "$1";
        try_files $uri @root_path;
    location @root_path {
        rewrite ^/(.*)$ /$custom_index break;
    location ~ ^/([^/?&:'"]+)/config.js$
        set $subdomain "$1.";
        set $subdir "$1/";
    # Matches /(TENANT)/pwa-worker.js or /(TENANT)/manifest.json to rewrite to / and look for file
    location ~ ^/([^/?&:'"]+)/(pwa-worker.js|manifest.json)$ {                                                             set $subdomain "$1.";
        set $subdir "$1/";
        rewrite ^/([^/?&:'"]+)/(pwa-worker.js|manifest.json)$ /$2;
    # BOSH for subdomains
    location ~ ^/([^/?&:'"]+)/http-bind {
        set $subdir "$1/";
        set $prefix "$1";
        rewrite ^/(.*)$ /http-bind;
    # websockets for subdomains
    location ~ ^/([^/?&:'"]+)/xmpp-websocket {
        set $subdir "$1/";
        set $prefix "$1";
        rewrite ^/(.*)$ /xmpp-websocket;
    location ~ ^/([^/?&:'"]+)/_api/room-info {
        set $subdir "$1/";
        set $prefix "$1";
        rewrite ^/(.*)$ /_api/room-info;
    # Anything that didn't match above, and isn't a real file, assume it's a room name and redirect to /
    location ~ ^/([^/?&:'"]+)/(.*)$ {
        set $subdir "$1/";
        rewrite ^/([^/?&:'"]+)/(.*)$ /$2;
        set $subdir "$1/";
Contents of /etc/nginx/meet.caviomorpha.dev.conf
And what about matrix can you post that. It has the emerg error in it
This section is also defined twice.
I'd suggest updating your global nginx config to include tha wasm content type, then remove it from your individual sites.
